do wires make a difference
I have been looking around to see if a coil and wire change will get me more hp and even more mpg and i have seen a lot of different thing i have seen wires that are the same size as stock or thicker, that they come in all different colors but i have headers so i know it will be getting hotter by the headers then what stock is, and for coils i hear the stock works just fine is that true is there does anyone make an aftermarket coil that works better ???
Re: do wires make a difference
From what I have seen there is little to nothing to gain over the stock LS3 stuff.
They will make a difference if your engines has 700hp where you need a hotter spark. I'm not sure what is the best way to get more hp out of the 5th gen. look into getting a Cold air intake and better flowing exhaust
Originally Posted by parkers Z28
(Post 6946383)
JMHO SteveC :) |
msd wires are cheap and work cant hurt ... especially with headers
Originally Posted by micheal23
(Post 6973777)
IP = Pakistan Kamalia Usf Dslam Central |
Originally Posted by Injuneer
(Post 6973782)
You IP address indicates you are posting from Pakistan. Are there many 5th Gen Camaros there?
Originally Posted by ZeeS7o7
(Post 6974803)
Camaro or Camel? :lol:
In a mostly stock engine you'll notice zero difference from swapping out the wires. Put your money into other mods if you want a performance increase. Nice bright colored wires look nicer though.
| All times are GMT -5. The time now is 12:23 AM. |
