6 cylinder options in the Camaro?
Old Oct 6, 2006 | 07:21 AM
LeadSled1's Avatar
Question 6 cylinder options in the Camaro?
The original 1st gen Camaro had a straight 6 (250ci 4.0) motor. I wonder if Chevy is thinking of using the straight 6 4.2 that is in the Trailblazer for the base models? It puts out 291hp in the SUV. This would be an awesome motor to have a supercharged or turbo option also.
Old Oct 6, 2006 | 07:43 AM
ImportedRoomate's Avatar
Re: 6 cylinder options in the Camaro?
Not a chance. Its way too tall and probably too long to fit.
Old Oct 6, 2006 | 08:25 AM
LeadSled1's Avatar
Nope, it will fit.
Requires a different oil pan and a different intake.
Old Oct 6, 2006 | 08:27 AM
LeadSled1's Avatar
Here is a good read on the engine. Variable valve timing etc.
http://media.gm.com/division/powertr...0_Overview.pdf
Old Oct 6, 2006 | 08:39 AM
Z28x's Avatar
GM will be making a Direct Injection 3.6L V6 with over 300HP soon.
Originally Posted by LeadSled1
Nope, it will fit.
What car is that in?
Old Oct 6, 2006 | 09:38 AM
Jacoz35thSS's Avatar
No way on the I-6 for the Camaro. They have much better car based V-6's. This is designed for turck applications and even negating the weight and set up on the TrailBlazer, the I-6 get horrible fuel economy. 2WD TB gets 16/22 and believe me that is not what I have seen, worse. So, they'll put something in more car based.
Old Oct 6, 2006 | 10:55 AM
MarcR94v6's Avatar
[QUOTE=Z28x]GM will be making a Direct Injection 3.6L V6 with over 300HP soon.
/QUOTE]
I have a feeling they won't use it in the V6 Camaro, though, might make it too pricey, seeing as how we're only getting one V6.
Old Oct 6, 2006 | 11:27 AM
LeadSled1's Avatar
Well, the 6.0 in the Trailblazer only gets 15/19. In the Corvette it gets 17/27. Using that difference in weight and aerodynamics that would put a I-6 equiped Camaro above 30mpg with 300 hp.
Old Oct 6, 2006 | 11:29 AM
LeadSled1's Avatar
Z28x, I forgot to mention that is in a Chevy II.
Old Oct 6, 2006 | 03:07 PM
DvBoard's Avatar
a inline 6 would be nice, however it's seen as an "old" engine. It will take some marketing, and nice numbers (MPG & HP) to get people to buy it.
Old Oct 6, 2006 | 03:38 PM
97z28/m6's Avatar
BMW.
Old Oct 6, 2006 | 03:41 PM
Good Ph.D's Avatar
Do we know that? Clearly thats likely but you never know.
Someone better tell all those 3 series owners their engines are "old".
Old Oct 6, 2006 | 03:54 PM
Z28x's Avatar
The 4.2L I6 came out in 2002. It is DOHC w/ VVT it isn't that old. a DI version would be 330HP+
People would love to have one in the Camaro
[QUOTE=MarcR94v6]
/QUOTE]
It will be out in January in the 2008 CTS and is said by many reliable people here to be going into the Camaro. This might be a optional V6 though.
Old Oct 6, 2006 | 04:25 PM
MarcR94v6's Avatar
Well, I trust your judgement/sources from what you've said in the past, so that makes me very excited! Optional, or not.
Old Oct 6, 2006 | 06:16 PM
DvBoard's Avatar
think public, not the enthusist. If they here it has the same type of 6 cylinder that used to come in camaro's they are going to think they are no better than they where.
