l99 to ls3 swap question???
Old 05-09-2018, 09:58 AM
wideglide2011's Avatar
previos owner says he did the swap from l99 to ls3? but how can i tell from a visual inspection??? thanks for any help.
wideglide2011 is offline
Old 05-09-2018, 11:12 AM
DrewHMS97SS's Avatar
Re: l99 to ls3 swap question???
I am mostly ignorant to the newer Camaro's, but it looks from brief reading that the L99 came with automatics, where the LS3 came with manuals.
Camshaft Upgrade - Too Fine L99 - GM High-Tech Performance Magazine
I am not sure you can really call it a swap. Look at the differences listed in the article. To make it an LS3, there would have had to have been a cam swap, changes to the heads, and unknown changes to the computer to disable the AFM and VVT components.
If you still have contact, I would verify what was actually done.
DrewHMS97SS is offline
Old 12-30-2018, 11:40 AM
383z93's Avatar
I think he was taking about a cam swap and supporting valve train to get rid of the VVT and AFM which needs a tune to to get rid of them.
In the 5th Gen world listed above is a "LS3 swap."
383z93 is offline
Old 12-30-2018, 11:47 AM
383z93's Avatar
L99 and LS3 are the exact same on the outside EXCEPT for the timing chain cover.
L99 has a phaser cam location and the LS3 does not.
If you have a regular timing cover as pictured on the right it could be a LS3 or a L99 with a cam swap basicly.
383z93 is offline
Old 12-30-2018, 11:57 AM
383z93's Avatar
The ONLY way to know is to take off a head and see if the pistons have Valve reliefs for VVT.
383z93 is offline
scottnorton
11-06-2008 09:47 PM
RRR
Advanced Tech
9
08-03-2007 11:00 PM
klpps
09-21-2003 05:31 PM
talos
Pacific
20
07-24-2003 12:54 AM
Quick Reply: l99 to ls3 swap question???
