Am I the Only One..?
They may have been the highest quality F cars built, but they were still poor in quality and reliability in terms of a vehicle. The automatic transmissions were garbage, along with the rear-ends - a 12 bolt should have been standard. What about the oil leak behind the intake manifold on the LT1s? The window motors? The piston slap with the LS1's? As fun as it was, I sold my first LT1 because it was an omen and a money pit. There is no denying that all of these problems were common across the board with 4 gens, and that they are inexcusable results of poor engineering and QA.
-"Garbage" Transmissions? Don't know about that. I've had ZERO problems with my two A4's, in fact my 96 "beater" has the original tranny @ 106K miles.
-"Garbage" Rear Ends?
They were more than strong enough for my "spirited" street driving and occasional blasts down the 1/4 mile. SURELY anyone that is "serious" about racing realizes that breaking parts is a risk you take. But the VAST MAJORITY of owners will never have a need for anything stronger. I will admit though to putting a rear end girdle with pre-load bolts (correct term?) on my 01 SS "just in case". -Neither of my LT1's had the rear intake oil leak.
-Window motors? Out of the three, I've only had to replace the driver's motor on my 106K mile "beater", but I will admit the passenger's is on the way out. But I never had a problem with my 95 Z or '01 SS motors.
-Piston Slap? Big deal. Some LS1 Corvettes had the issue as well. Hell, my '01 SS would slap when it was VERY cold, but like all the others it would go away once the car warmed up a bit. Piston slap was a NON-ISSUE as far as reliability/longevity was concerned.
Sorry you had a bad experience with 4th Gens, but from 1997 to present I've owned three for a combined total of about 8 years and 60,000 miles. The only "real" issues I've had are a bad EGR valve, one bad window motor, two torn tranny mounts and a leaking water pump seal (at 106K miles).....that's it.
It seems your bad experience with your LT1 has tainted your opinion of GM in general.
Did I forget to mention that I will wait. And I will be happy. And I will be satisfied? Nope. Didn't think so.
Such as the ZR1 can be considered the best Vette ever -- the new Camaro will be the Best Camaro Ever.
Can't wait to prove myself right. Again. <sigh>
Let all the haters and doubters take a subtle exit to -- stage left. The bouncers are waiting for you.
FBODFATHER- Just PLEASE let us know when it will be fiscally responsible to start putting in deposits for the V8 model of this beast. I dont want the Top Dog - I just want 400+ ponies in a reliable coupe. And then, the circle between my '69 and the "New '69" will be complete.
You are most-welcome to drive her anytime you wish, should you decide to visit Big D. My pleasure.
You guys have to remember that in 2000 the car was suppose to be dead there was never suppose to be a camaro coming back. So how can they release a concept on a car that was deamed dead?
There wasnt even a smuge of hope of the car coming back until 04 & even then there wasnt really a light at the end of the tunnel it was just a flicker. it wasnt until the end of 05 that we started to see the true lights & as scott said it wasnt until August that we really had any hope of the camaro coming back....
I would suggest that we all had a pretty good idea the car was coming back WAAAAYYYY before 2005 - we simply didn't know when, and most didn't expect it to be 2009 as a 2010 model.
Bob
The car was already on the way to being dead in 1997 or so. I believe it is accurate that 2000 was supposed to be the last year, but they managed to hang on for another couple of years. It was on "hiatus" after 2002 but there were no real plans for another one at that time. I think there were just a few documents and very basic cases studies for a long time that had just as much of a chance of being filed away somewhere and turning to dust as it did growing into a production car.
Dear Mr. Malice.
A little history lesson first......
The name Camaro means 'Friend, pal, or Comrade....."
This is a Camaro site -- yes, it's a free country -- however, I notice that:
#1 -- you are new on here.....(I make that assumption based on the number of posts.....)
#2-- there is Zero personal info. about you --- (and that makes me suspicious.....)
I'm curious as to what your profession is.
Have you ever engineered a car or truck? If so, I'd be interested in which vehicle(s) it was/were.
I will agree that the power window motors were very problematic.....and I know this because we replaced many of them under warranty and many of our enthusiasts contacted me about it -- or told me about it as I travelled all over the country to attend Camaro/Firebird shows.
As to your charges that the transmissions were ...." Garbage " (your word, not mine) I would ask you to please show meaningful evidence and the data to back up this charge. (you can't.........and "well mine and my buddy's failed" isn't meaningful data.......)
Yes -- a 12 bolt should have been standard -- and we should have had larger brakes -- and many other parts should have been more "heavy duty" -- there's a problem with that -- and it's called "weight" --(wanna get peopel hysterical once again on this site? Bring up 'weight' and sit back and watch the fur fly......) ............ Adding a heavier axle and brakes and such would have negatively affected CAFE not only for the F car but the entire GM portfolio. The number of axle failures are very low -- below industry average, as a matter of fact -- and that's WITH the knowledge that most axle failures are due to drag racing or 'stupidity" ( by 'stupidity" I mean "Hey everyone - watch me ruin a perfectly good set of Goodyears!!!!" -- as I unfortunately witnessed all too often........)
Piston Slap? Most of what people consider to be 'piston slap' is actually noisy fuel injectors or, in some cases, bent pushrods -- (from that "hey everyone-- watch me ruin a perfectly good get of Goodyears and a couple of pushrods!!!)
You may be interested to know that we repurchased several dozen Fcars with LS1engines that exhibited more noise than normal -- and ran some of them at the rev limiter for 24 hours or more -- and took others north of 250K miles -- none failed. I'd say that this is a great testament to a great engine family.
You may also be interested to know that the early 4th gen cars won awards for quality -- and in fact if you go back to read magazine articles in that timeperiod, many journalists talked about the great quality. The problem is that the car got old.
I'm not saying the Camaro (and Firebird) were world-class quality leaders -- but they weren't as bad as you seem to be making them.
Further, a decision was made to end production at the end of the 1998 model year--- and this decision was made at the end of 1995 or early 1996.........we were able to keep it in production thru 2002 based on demand for the LS1 engine which drove profitability. (you'd fall off your chair if I told you how much money we lost on the Fcar in 1996-1997.....)
(Do you want to guess when the initial engineering took place on the 4th gen architecture?)
I don't mean to flame you -- but you need to perhaps chill a bit and learn a little bit more about the 4th gen Fcar. And perhaps you need to attend a few Camaro/Firebird shows and look at the cars out there with little or no warranty claims..................
Competitive at making rental cars. Giving the entire ponycar, police and taxi market to Ford was a mistake. Currently GM is also seen as unable to compete with foreign makers in terms of build quality and design. GM has been on top for so long they forgot to try. Companies like Hyundai are trying really hard to take down companies like GM. The problem is GM keeps letting them win.
Ford is by no means an example of how to do business. But the point is if you go to rent a car you will be sitting in a stripped down Malibu that is impressive only in how crappy it is. Everyone I know that travels for business is aware only of the poor quality of GM and Ford. My comment was intended to show that most people regard GM and Ford cars as rental/fleet cars. Not something you would go out and buy. That being said almost all cop cars of Ford and Mustang is the only car of its class. GM simply gave up two huge markets there. The point is to sell cars.
Mustang is the only car in its class? What class is that? Muscle Car class?
In the 2 door sports coupe class, it is not alone. Just cause a 40 year old name got put back in rotation doesnt make the Mustang any different then any other 2 door sports coupe.
I have seen a lot of new Malibus at the dealer lot but not one on the street. I have seen plenty of Sonatas, Accords and Camrys on the road and in peoples driveways. The fact is GM and Ford relied too heavily on truck and SUV sales. With gas prices and ever growing competition GM and Ford are looking at serious problems.
GM and Ford did rely on the heavy profit SUV's, but guess what sells at a million units a clip? I guess they put their money on there best selling product. They didnt forsee that there would be heavy speculation in the gas market, artificially inflating the cost of gas, on top of the dollar falling like a rock off a cliff. Not to remind you boys and gals, that 5 years ago gas was cheaper a gallon then water was for 20 oz or 1/3 the price of a tall mocalatte from Starbucks.
And to tie it all together, take a quick peek again at Green Toyota Tundra and bigger and thirstier Sequia. Toyota is falling into the truck trap as well, but people are still buying.
Letting the Camaro die was a mistake and reaction to making a new Camaro was and continues to be a slow process. The Japanese are still more efficient at development and production. The Camaro is a niche market with strong customer support. To let that languish like GM did till its ultimate death is just plain bad business. As the global oil market continues to fluctuate, and environmental concerns form new regulations, the 5th Gen may be too little too late.
Was it too late or Chevy to release a Camaro 3 years after Mustang launched to over 1 million units sold in the first 1.5years?
Was it too late for GM to launch a modern high tech tuned port fuel injection to give us both performance AND economy, breathing life back into the whole muscle car?
What is Camaro late for? Do you have some where to be come this time next year, andyou need a 2 door sports car? Global oil market, blah blah blah enviromental jiberish crap.
LS1 Fbodies got up to 30mpg in highway crusing, it was a ULEV engine, and oh yeah IT MADE 300HP.
Please, tell me what Camaro is late for? Is it too late for you? Cause its not too late for me. Hell, its almost right on time.
If its too long for you or anyone else, please dont waste your time posting on here. Take your money on down to Ford, pick up one of the 20348u03248203843 variations of the Mustang GT with whatever decoration package you wana throw together and be done with it, "before its too late!"
And everything else, hault so we can get this car out to people!!
99SilverSS
Thanks for the input, I know its my opinion. BTW public opinion matters and GM must improve its public perception. I also feel GM is making better cars, but it takes a lot of rights to sway the masses. However, the point of this thread is your "opinion" on Camaro development time. I simply state that the wait between 1993 and 2010 is too long. You can argue till the cows come home about your world and mine, but waiting 17 years for a new generation Camaro is a long time, period.
If you have been waiting from 93 to get a new Camaro...dude, thats really really sad.
Ive been waiting 24 years to own a Camaro, my first Camaro that I purchased new with my money, the way I wanted, so I can park it next to my other 2, which were purchased new by my father and grandfather.
Sorry if I come off a little harsh, but I have been growing sick of hearing "opinions" of people about the Camaro taking too long.
I grew sick of people laughing in my face saying that Camaro would never return.
I got sick of people telling me that GM wont ever make a quality car
I got sick of people giving me thier opinions that Chevy would butcher the Camaro when it returns.
But you know what happens? I let my laptop rest for 7 mins, and it flashes that awesome (thanks Jason) Camaro concept screen saver. It takes me back to that wonderful morning in Cobo Hall, watching, hearing, feeling what people told me would never happen.
Dear Mr. Malice.
if the window motors were a known issue, why were they not fixed? or changed? i've been in a buick with windows that seemed to be the same size or larger than my camaro's and its windows fly, so there was absolutely a parts bin motor that could have been used. where did the window motor come from? was it a parts bin part or was it designed for the f-body?
when was the engineering done on the 4th gen f-body? late 80's?
did piston slap show up in testing before production? or was this one of those things that showed up in production vehicles and it was deemed fine? my camaro's piston slap you can hear clear through the house and can be heard at all times when its cold out, even when the car is warmed up
oops i guess thats four questions
One of the things that people see (present website excluded) and one of the problems,
is that the car was shown in a concept form, (that pretty much reflects what the final outcome will be, or at least 95% of the look) a while ago.
Change a dimension here or there, or even some fine points, it still looks extremely close to the final design.
We have had now entering Autoshow Season #3 and you can still not buy the car.
Showing it so early, it is extremely hard to keep the hype train at full tilt.
I do know a lot of people who have lost interest in it.
The faithfull will stay, but some will just get tired of waiting.
three questions, if you'd be so kind...
As for the OP in this thread, I agree with him about keeping the faith and yes, waiting is tough to do. But for him to malign the overall 4gen design is incredibly short-sighted and ill-informed. That design was an incredible performance coupe achievement for its time and an outstanding value for its buyers. I expect the new Camaro will be the same
And those drivers didn't just "watch their cars spontaneously combust" due to no fault of their own. While the rods are admittedly an inexcusable design flaw, it is still the responsibility of a car's owner/driver to make sure that there is actually oil in the engine.
Amen to that brother
! I agree, the power window
gets tiresome.Hell, I had to replace 2 window motors on my 92 Z28 within a month of each other....I think I'll go to thirdgen.org and
about it now.
