Diy sequential tail lights
8 Attachment(s)
This is a really easy mod and only should take about 30 minutes
Got them here 89$ http://www.southerncarparts.com/prod...oducts_id=3126 Attachment 12186 Attachment 12187 Attachment 12188 if you have big hands this can be tight Attachment 12189 Attachment 12190 Attachment 12191 Attachment 12192 Attachment 12193 re install the socket and repeat on the other side http://www.youtube.com/watch?v=PsNGZoK0w2Y a link from our buddy Jay Debler . http://www.youtube.com/watch?v=g71UzcvZjEo |
Re: Diy sequential tail lights
Nice! This is an easy mod that is almost fun to do.
One tip...make sure you put dielectric grease on all contacts if necessary. I even use the stuff on household bulbs. Cheap insurance. |
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=1702& transactionid=1315753552-6819721635&posted_by=Mucker15_www.camaroz28.com&yo utube_video_id=PsNGZoK0w2Y[/autostream]
Has anyone who did this noticed a "check rear bulb" warning on the DIC after installing this? I get that sometimes when I am done using the turn signal. However, the bulbs are fine.
I think that when I move the turn signal lever to the "off" position, it is sometimes in mid-sequence...like the one bulb has fired but the other one didn't, and somehow the lighting system knows it and thinks it second bulb in the sequence is burned out. |
Yes the check bulb info comes on pretty often.Today though it came on and the signal is flashing quickly.This sounds like a bulb.When she gets home it's taillight fixn' time!:yes:
