z06 Rims Spacers
z06 Rims Spacers
I have a 1994 z28 that i had just gotten some 2003 z06 rims for. The front fit perfect but the back will rub. I was wondering if anybody knew what size of off-set spacer i should get and if I'll need to buy longer studs. Any information would help. Thank you.
Re: z06 Rims Spacers
Generally not a good idea to "cross-post" the same problem on two different forums. I responded to your identical post on the "Suspension, Chassis and Brake" forum.
