Torque Thrust II's will they fit
I'm looking at buying two TTII wheels for the front of my 2001 Camaro Z28 and the guy say they fit my car and has a backspacing of 4 inches(wheels are 17x8) will these wheels fit on my car without them sticking out from under the fenders?THANKS
Re: Torque Thrust II's will they fit
The stock 8" wide 4th Gen wheels have a 55mm offset, giving them a 6.63" backspace and a 2.3" frontspace. If you use an 8" wide wheel with a 4.0" backspace, the frontspace will be somewhere between 4.25 and 4.50". That will put the outer edge of the tire well outside the front fenders. Look at your stock wheels and think about what they would look like if they stuck out an additional 2" beyond where they are now.
In the back, they will be slightly outside the fenders, and will rub on the fender lip.
Why are you even thinking about an 8.0" wide wheel.... no wider than stock?
The offset is +46 and the back space is 7"on the 17x9.5"s Torq-Thrust II D 2 piece polished aluminum wheels.The Summit Racing website has the wheel in all sizes and widths and lists the back spacing.
Interesting.... but he is asking about 17x8" TTII's, with a 4" backspace.
Sorry he can still go the Summit web site and the info he's looking for.But he did ask the back spacing of my wheels.Interesting.
The problems with the inner fender and the bump stop bracket will be reduced or eliminated. The problems with the outer edge of the tire and the fender lip will be worsened.
Read the part of the FAQ post that explains that there is a large difference in the assembly tolerances from car to car. You may have more problems or less problems than someone with a seemingly identical car/wheel setup.
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
CARiD
01-27-2015 06:27 AM
