2010 Camaro Wheels Fit on 93-02??
Does anyone have pic's or know if the 2010 rims off the new Camaro's will fit on older models??? Im redoing another 95Z and would like to see em on the car before i buy. Thanks for any help!!!
doubt it, new camaro has staggered 19/20's doesnt it?
or 20/21's I forget, I know the concept had 22/22
Whether the wheels "fit" has nothing to do with the diameter of the wheels, or the fact that they are "staggered".
The first problem is the 5th Gens have a 120mm biolt pattern, and the 4th Gens use a 120.65" (4.75") bolt pattern. Whether its a good idea to use the 120mm bolt pattern on the 4th Gen has been discussed extensively. Some people claim they have run 120mm wheels (BMW for example) with no problems, others have cited problems with the lug nuts coming loose and the studs breaking.
The next issue is the offset of the wheels. You need to check the offset of the various 5th Gen wheel sizes (18", 19", 20") and compare it with the guidelines in the FAQ for the 4th Gen.
Re: 2010 Camaro Wheels Fit on 93-02??
in my honest opinion 20 inch wheels look so ugly on a 93-02 Camaros....it makes it look jacked up front and back and just looks cheap , might as well put a double spoiler on the back.......17's are perfect on those cars..maybe 18's at most.
Looks like the rear fender sheet metal has been bowed out to clear the tires. I guess not everyone has the same definition of the word "fit".
