[Texas] need a 94-95 rearend
I need a disc brake, 4 channel out of an a4... looking for 3:23 posi... but a 3:42 from a m6 will do. Preferably in the Beaumont area, but being realistic.... Houston would be cool.
Re: need a 94-95 rearend
Since you had no response I figure I'll offer you my old rear end. I'm in the Dallas area.
Full rear-end housing
Eaton posi-unit with about 6 months of use (10,000 miles shooting high)
3.73 gears
LCA weld on relocation brackets
T/A aluminum rear end cover
With the exception of welding the tubes, this is about as built of a 10 bolt as you can get. I pulled it for a 9inch to match my new stroker/blower motor. This rear-end never saw it.
$900
3.73 gears
$900
Needless info to follow.. just an update on my return.
So I was formerly a mechanic with Nissan.(00-07).and the way we did things with warranty cars and the way I have to do things on this car...well...there's a huge difference..
But I bought a set of makita tools..3/8 impact, drill, two lights(spot and drop)
I sold all of the tools I had acquired as a Nissan mechanic...and man...I'm glad I got these things..I had forgotten how fast you can do a job, with the right tools..
But, my car had been doing a nose stand in the driveway.. but the rearend is back together...now I need to replace the drivers side temp sensor that mysteriously broke....probably dry rot...idk. but its going to be good to get her running again...
SpraydZ
06-07-2016 01:44 PM
