D/FW area dyno day!! ** and oil/fluid change special
Old 07-19-2003, 08:30 PM
  #31
Texas Moderator (1998-2009)
Shawn 97 Z28 M6's Avatar
stock!? that's a problem right there
Shawn 97 Z28 M6 is offline
Old 07-19-2003, 08:40 PM
  #32
quicksilver97ta's Avatar
Finally, just a few hours ago I found the problem. A small toothpick size hole in the top of the head into #6 intake runner. Doh!! Thats where all that oil was coming from... Duh. Anyway I patched it with some "quik steel", yes I know, temporary. I want some dyno #'s though, I'm gonna try to make it.
quicksilver97ta is offline
Old 07-19-2003, 08:43 PM
  #33
rage366's Avatar
well, i didnt think it would be a problem...i thought at be using about 95% of the injector's power...not the whole thing...will the dyno's a/f be able to tell me if that's the problem?
rage366 is offline
Old 07-19-2003, 09:50 PM
  #34
Nope... won't be able to tell if your injectors are going static or not... But if you can see what RPM they're reaching their full duty cycle at, then that's already a bad sign. <- speaks from experience..
Old 07-19-2003, 10:44 PM
  #35
rage366's Avatar
shawn, unlike your car, i doubt that my car can run 11's with my mods...so, do you really think that i'd need bigger injectors? i mean, i can understand why you'd need 30lb injectors.
i figured that with my mods, i'd be lucky if i can get about 360rwhp...
so, ya think that freescan will be able to tell my injector cycle? if not, then what will?
rage366 is offline
Old 07-19-2003, 11:02 PM
  #36
if I get a chance tomorrow I'll see if the scanner we have there can read the duty cycles.
In my 355 w/ head/cam I made 370rwhp or so... At the stock injectors maxxed out at 5600rpms... After that they never turned off.... Just kept pumping fuel in the motor. Found this out at Hallville making shakedown runs w/ the "new" at the time - motor.
Old 07-19-2003, 11:05 PM
  #37
rage366's Avatar
well, if ya have it, i'll bring my car to ya in a few days to get it dynoed...right now, there seems to be an oil leak for some friggin reason...brand new motor!! wtf!!
well, anyway, once this issue is taken care of, i'll probably bring the car to ya on wednesday...i'll let ya know before hand.
oh yeah, was your cam the same size as mine? bigger? smaller? did ya have an A4?
rage366 is offline
Old 07-19-2003, 11:13 PM
  #38
cam was similar... CC306.. 230/244, but w/ an M6.
Old 07-19-2003, 11:22 PM
  #39
rage366's Avatar
well, my bigger cam and your m6 should cancel each other out...
what kindda compression were u running? any idea on how your heads flowed?
rage366 is offline
Old 07-19-2003, 11:39 PM
  #40
just over 12:1.. heads were around 250/180 I figure... A "school project" if you will.
Old 07-20-2003, 01:48 PM
  #41
AW/whiteZ-28's Avatar
Sorry I couldn't make it guys
Car started stalling this morning so now I gotta figure out what it is
AW/whiteZ-28 is offline
Old 07-20-2003, 02:36 PM
  #42
Schismblade's Avatar
Can all Kwik Cars dyno?
Schismblade is offline
Old 07-20-2003, 05:17 PM
  #43
95GRNZ's Avatar
Cool
I'm happy with the results
297hp/309lb.ft
Thanks guys!!!
TS
95GRNZ is offline
Old 07-20-2003, 07:09 PM
  #44
297hp/309lb.ft
Thanks guys!!!
TS
What mods?
Old 07-20-2003, 08:33 PM
  #45
95GRNZ's Avatar
Cool
Originally posted by AW/whiteZ-28
What mods?
None which would have given me any hp: K&N filter and Flowmaster muffler (your old one). Most likely no effect.
Pretty much stock.
95GRNZ is offline
Quick Reply: D/FW area dyno day!! ** and oil/fluid change special
