Budget 355 lt1 Q's
Budget 355 lt1 Q's
How much did you drop on a budget 355 build? I would like to start planning for a 355 with a monster hydro. cam, and home port heads, on a motor that can handle a 150 - 200 wet shot.
Plans are: Th350 4000-4500 stall, 355 with spray,
I have a 10 bolt with 4.10's, as well as a fuel system that will handle up to 1200 hp.
any info on the motor would be greatly appriciated.
Steve'o
Steve'o
Re: Budget 355 lt1 Q's
Originally Posted by Z28SORR
Not sure you will get much response, as you have two totally incompatible statements. I don't think you CAN, do what you ask on a budget!!
Thanks,
SteveO
If your not planning on spinning the eng to high. I would just use the stock rods and crank with some good pistons such as Speed pro and some ARP bolts. If your looking for some thing that can handle a good amount of abuse but still cheap go with some Eagle or Scat crank and rods with some Speed pro pistons. Just remember you can only make as mutch power as your heads will let you. So put the $$$ in the heads.
just my thoughts
just my thoughts
just my thoughts
just my thoughts
Snake: I was being a little facetious, though I might decide to sell it shortly. However, I did to be what I consider a good balance between budget and strength.
Scat cast 3.75 crank
Scat 6.0 forged rods
Diamond pistons.
I bought the rods and crank off of Ebay for about ~320 bucks delivered. I bought the pistons from the builder for ~600. The rest is just finding a block and doing the machine work.
Ryan
Diamond pistons.
Ryan
Here are some options with pricing. If you have any questions, don't hesitate to contact us.
VRE 355LT1 Economy Shortblock-$2999.99 NO Core Charge
-Eagle 3.480” stroke Cast Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs
VRE 355LT1 Racer Stage 1 Shortblock-$3290.00 NO Core Charge
-Eagle 3.480” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings, Clevite Cam Bearings, ARP Main Studs
VRE 355LT1 Racer Stage 2 Shortblock-$3590.00 NO Core Charge
-Eagle 3.480” stroke 4340 Crankshaft, Compstar Connecting Rods, Diamond Pistons, Diamond Pro Select Rings, Clevite Main Bearings, Clevite Rod Bearings, Clevite Cam Bearings, ARP Main Studs
Originally Posted by bdc95ta
Yeah guess what I just found out the engine builder didn't even clearance the stock valvecovers for the pro mags! I guess 4g's doesn't buy ya much these days.
-b
-b
LS1 swap? Haha. Sure, stock shortblock vs stock shrotblock the LS1 is king. But a built LS1 will cost much more than a built LT1.
Originally Posted by Josh'95Z28conv
No it dont. I have wayyy more than that into mine, and Im not done yet.
Steveo
