West North Central Iowa, Kansas, Minnesota, Missouri, Nebraska, North Dakota, and South Dakota
2008 LTX Showdown -- Cordova, IL Sept. 7,2008
Old 05-05-2008, 11:42 PM
tspence45's Avatar
http://ltxshowdown.forummotion.com/index.htm
A local guy decided to organize this, because he missed the LTX Shootout this year. It's got all the same rules as the LTX Shootout, too, I believe. It's only an hour from me, so I think I'll be up for it. Anyone else interested?
tspence45 is offline
Old 05-11-2008, 03:56 PM
jakesz28's Avatar
Thanks for starting the thread
I hope to see many cars turn out for this event.
SHOWDOWN rules
Classes, Rules & Payouts
Classes and rules are subject to change.
Payouts are estimates depending on event participation.
LTX Outlaw
• Run what you brung HEADS UP format
• Limited to quickest 16 qualifiers
Must have LT1 based engine. If heads do not retain factory 23° valve angle, a 150 lb. weight penalty will be enforced. Converted intakes, sheet metal, or stock intakes allowed. Multiple power adders allowed. 10.5 tire max (W’s limited to 29.5). Drag radials permitted any size. Stock style suspension preferred. If you have a 4-link or similar setup a 150 lb weight penalty will be enforced. Mini tubbing allowed. Wheelie bars allowed. No back half cars. Mufflers are an option. Any carburetor allowed. Any EFI system allowed. Any OEM style transmission allowed. If Non-OEM style transmission, a 100lb weight penalty will be enforced. Lexan permitted. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Weight 2800 nitrous 3300 forced induction.
Class Sponsors:
Estimated payout: TBD by participation
LTX Drag radial (Power Adder)
• Limited to quickest 32 qualifiers
Must have LT1 based engine. Heads must retain the factory 23° valve angle. Converted intakes, sheet metal, or stock intakes allowed. Single power adders only. Nitrous must be single stage. Supercharger FIA,YSI max. Turbo limited to 81mm. Twin turbo setups must send details of setup to the organizer for decision. Drag radials permitted any size. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any EFI system allowed. Any one piece carb allowed. Any OEM style transmission allowed. Must have factory glass (no Lexan…etc). Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Nitrous only cars get 300 lb weight break off the minimum. Minimum weight limit 3200 lbs.
Class Sponsors:
LTX Heads up N/A (Naturally Aspirated)
Must have LT1 based engine. Heads must retain the factory 23° valve angle. Converted intakes, sheet metal, or stock intakes allowed. No power adders allowed! 10.5 X 29.5 tire max. Drag radials permitted. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any carburetor allowed. Any EFI system allowed. Any OEM style transmission allowed. Must have factory glass (no Lexan…etc). Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Minimum weight limit 3200 lbs.
Class Sponsors:
LTX Heads up 6-speed
Must have LT1 based engine. Heads must retain the factory 23° valve angle. Single stage power adders allowed. Aftermarket intakes allowed with a 100lb weight penalty. Stock PCM only (Aftermarket EFI 50lb weight penalty). 10.5 X 29.5 tire max . Drag radials permitted any size. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any carburetor allowed. Any OEM manual style transmission allowed. Must have factory glass (no Lexan…etc). Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Minimum weight limit 3200 lbs.
Class Sponsors:
LTX Extreme Street
Must have LT1 based engine. Heads must retain the factory 23° valve angle (no converted SBC heads). Only stock/stock style ported intakes allowed (welded intakes not permitted). Single stage power adders allowed. Stock PCM only (no aftermarket EFI). Opti-spark distributors only no rear mount allowed. Coil per plug allowed. DOT tire only. Maximum size 28" X 10.5" (actual tread with). Only exception will be 315/35-17 drag radials, 325/50R15 allowed, dr limited to 28”. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any OEM transmission allowed. Must have factory glass (no Lexan…etc). Must have working lights, wipers, and horn. Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Minimum weight limit 3400 lbs.
Class Sponsors:
LTX Bracket - 12.49 & Faster
• No limit in entries
Must have LT1 based engine. Transbrakes allowed. NO electronics ( delay boxes, throttle stops..etc). Car and driver must meet NHRA/IHRA certification requirements for the times the car is running.
Class Sponsors:
LTX Bracket - 12.50 & Slower
Must have LT1 based engine. NO electronics (transbrakes, delay boxes, throttle stops..etc). Car and driver must meet NHRA/IHRA certification requirements for the times the car is running.
Class Sponsors:
jakesz28 is offline
Old 05-12-2008, 05:57 PM
jakesz28's Avatar
I think we are going to let LS1 cars enter the bracket classes and have the fastest LSx go up against the fastest LTx. Does this raise the interest level?
jakesz28 is offline
Old 05-12-2008, 09:12 PM
Pullngz's Avatar
Do you know what it's going to cost to race yet? What's the registration process?
Mike
Pullngz is offline
Old 05-15-2008, 12:25 PM
magnumv8's Avatar
I will plan to be there.
Can you run in more than 1 class?
magnumv8 is offline
sleeperZ96BT
09-09-2015 08:28 AM
Javi Fierros
Wheels and Tires
06-11-2015 07:41 AM
NewsBot
01-11-2015 06:10 PM
NewsBot
12-30-2014 09:40 AM
Bg Drg
West North Central
07-23-2002 11:18 PM
Quick Reply: 2008 LTX Showdown -- Cordova, IL Sept. 7,2008
