Unidentified sound while shifting
Old 11-10-2011, 04:15 PM
Longwell's Avatar
Ok so i have a sound that I can not figure out. Every time I change gear from 1st to 2nd, or 2nd to 3rd while the engine is cold it makes the sound that you will hear in the video below. Also, sometimes it happens as i go on the gas after i shift gear. Like i can even "feel" the sound through the shifter if that makes sense. Its getting worse and worse and it's really starting to worry me. I checked my transmission fluid and its full so i know it has nothing to do with that, which is the extent of my mechanical knowledge haha.
I just think that its wierd that it also happens when i go on the gas sometimes. Because that means that it has to do with something involved in both parts I would assume. I may be dumb for suggesting this but could my serpentine belt have something to do with it because it was replaced two years ago and I think is due for a change, and in my opinion the sound kind of sounds like a belt slipping or something.
You can hear it at :14, :32, and alittle at :36.
http://s9.photobucket.com/albums/a58...t=IMG_2349.mp4
Longwell is offline
Old 01-02-2012, 01:45 AM
97QuasarBlue3.8's Avatar
Re: Unidentified sound while shifting
How's the clutch? They can chatter sometimes when worn and cold, and it slipping would explain why it happens when you get on the gas. The extra torque causes it to slip a little bit. Check the fluid, linkages, etc. Does it feel like a normal clutch? Good pedal pressure?
97QuasarBlue3.8 is offline
F'n1996Z28SS
08-23-2023 11:19 PM
RUENUF
03-13-2016 03:39 PM
04-16-2015 09:57 AM
jb4xx
02-02-2015 10:00 PM
Quick Reply: Unidentified sound while shifting
