Replace head gasket or replace engine...
I've got a 97' Camaro with the 3.8l V6 with 210,000 miles.
I just got the car about 3 weeks ago, and it ran great (just a leaky muffler, and in need of some interior tlc and some body work).
When I got it I checked the coolant and it was full, but I didn't think to check the mix. We've had really cold weather the last few day/nights (down to -4), and the coolant froze. I didn't know this and it ran for about 30 seconds before blowing the belt off, found that the water pump was completely frozen. I put it in the garage to thaw overnight. The next morning the water pump would turn, so I put the new belt on, started the car and it ran and sounded fine. I checked the oil while it was running and it was milky. Turned it off and checked the radiator for oil, there was none there. The freeze plugs didn't blow out, and there is no leaking oil or coolant under the car.
From what I can tell, it is the head gasket. But I'm not sure if it is worth it to replace the head gasket when the engine could go any time.
So I'm looking for some advice on how long these engines can last, would I be better off just replacing the engine?
Any help would be appreciated! Thanks.
Re: Replace head gasket or replace engine...
Too many unknowns at this point and it's already fairly high mileage, so I'd recommend replacing the engine.
Just a few months ago, I got one from a 2009 Buick with 44k on it for $550 from a local salvage yard. I see them advertised all over the place under 100k miles for ~$500-$600.
Yeah, I'm leaning toward a new engine. I'm going to have it diagnosed today or tomorrow.
If it's the gasket I may try to do it myself, it would cost about 2k to have it done. Though if it is the engine, I will have it done, I don't have an engine lift or anything like that. The price doesn't seem to bad, about 4k+/-.
The mechanic told me that, mdenz. He is going to call sometime tomorrow and let me know what we are looking at cost wise and option wise.
Like I said, $550 for a fwd Buick/Pontiac engine.
Swapping of components/accessories and R&R was done in 5 evenings in the garage. about 15 to 18 hours. A real mechanic with all the proper facilities/tools could do it quicker. That's hardly worth $3k+ in labor!
Both 2k for a gasket replacement and 4k for engine replacement are INSANE amounts!
PM me if a long explanation is required!
Thanks-Nick
Don't want to hijack the thread, but if a FWD 3.8 motor from a Buick/Pontiac can be swapped into a RWD car, couldn't the supercharger from a GTP/Regal GS be swapped into a 2002 Camaro with the 3.8? My buddy has a 3.8 Camaro, and I suggest the idea, but everyone says that because the supercharged motor is in a FWD configuration, it won't bolt onto the Camaro. Correct me if I'm wrong, but aside from possible clearance issues, shouldn't the Camaro's block be the same as the Pontiac/Buick's, just mounted different ways?
Thanks-Nick
Thanks-Nick
10-31-2016 11:09 AM
