OMG i'm changing my spark plugs
I'm changing my spark plugs on my '97 camaro 3.8 and OMG this is impossible!!! So far i've only been able to get 1 spark plug out and cut myself numerous times during the effort. Did any of you use any special tools for this, also did you remove the o2 sensors b/c I tried and they aren't budging, i even sprayed some WD-40 in hopes of losing it up. HELP!!!
-Mark
-Mark
Re: OMG i'm changing my spark plugs
update: i just cracked a swivel joint trying to remove the o2 sensor so i could get to the spark plug, I also seemed to crack a piece of porclin on a spark plug trying to losen it..damn it
dude, you dont need to remove any o2 sensors. if you are looking at the front of the engine, from the top, the front plug on the left and the two front plugs on the right can be taken out from the top. the other three get at from under the car. you will need a swivle piece, a small 1" extention, and a 3" extention.
Originally Posted by Hedzilla
get to 3 of them from the top, 3 from the bottom of the car. easier that way. takes me like an hour now.
yup that is what I did as well. It is the only way, 3 on top and 3 on bottom. I forgot which ones were the ones I got from the top though.
oh, and for the back left one or middle left one (cant remember which), you gotta put the socket, swivle, and extention on from under the car, then go above to loosen it. so put all the stuff on from under the car, then attach the wrench up top and loosen, then take everything off from under.
thats what I did and its how I broke the porclin. I guess since i have original plugs they are really in there tight. I used all the swivels and extensions and even tried a braker bar to losen it up but nothing worked, i'm gonna try again tommmorow.
you have a 99, itll be simple for you, you have tubular manifolds. For us pre 98 people, its a lot harder.
