3.4 horsepower increase
Old 11-23-2005, 07:42 PM
arctic white 94's Avatar
what are the best mods to do to a stock automatic 94 3.4 camaro to get more power and still keep it as a daily driver
arctic white 94 is offline
Old 11-23-2005, 09:21 PM
93 LT1's Avatar
Thumbs down Re: 3.4 horsepower increase
I have done the follwing and from stock I felt a big difference.
K&N CAI ($289.99)
Pacestter 3.4L full cat-back ($400.00 installed)
J.E.T underdrive pulley ($69)
Stock LT1 one piece driveshaft ($10)
J.E.T. 160* thermostat ($15)
I used my 93 3.4 auto as an everyday driver as well. The car was a real turd stock..this woke it up.
93 LT1 is offline
Old 11-23-2005, 09:57 PM
Black94Camaro's Avatar
or....
Magnaflow Dual Exhaust
FIPK Cold Air Intake
Headers, but they are expensive.
Any mod is a daily driver....
Black94Camaro is offline
Old 11-26-2005, 04:35 PM
tbird31's Avatar
93 LT1 you got any timeslips or know what it ran after you did all that?
I also have been looking for something to wake my slow a$$ car up...haha
tbird31 is offline
Old 11-26-2005, 04:53 PM
MarcR94v6's Avatar
Wow, you found a driveshaft for $10!!!
MarcR94v6 is offline
Old 11-26-2005, 08:44 PM
93 LT1's Avatar
Guys,
We are going back a while here. No times on my 93 3.4L but I can tell you that when I got it is was in mint shape but was a real turd. I mean slow as you can get. I seriously beleive the car was no quicker then my 91 Cavalier with the 2.2L.
It is still no rocket but it does move out 10x better with that stuff then when I got it.
The test vehicle was a 95 3.4L Camaro. Stock we ran a 16.3 I belive. After a pulley, CAI, 160thermo the car ran 15.9. This is WITH stock exhaust. I think my 93 is somewhere in the 15.7-8 range.
The driveshaft is stock steel one from a 94 LT1. Anything more then $10 and that is considered a rip-off!
93 LT1 is offline
Old 11-27-2005, 02:22 PM
2000GTP's Avatar
Check out the Parts for Sale forum, I have seen several go for that price. When I upgrade mine, it will most likely go in the garbage can as ten bucks isn't worth my time to package and ship it.
2000GTP is offline
Old 11-27-2005, 05:50 PM
transamtom's Avatar
I got mine for free..... off my LT1
transamtom is offline
Old 11-27-2005, 06:53 PM
MarcR94v6's Avatar
Yea, but wouldn't aluminum be better? I didn't know upgrading to an LT1 steel driveshaft would help.
Old 11-28-2005, 03:31 PM
93 LT1's Avatar
I think that any type of reduction in rotating mass helps free up HP. Did you ever hold the stock 2-piece V6 driveshaft? Heavy. Yes, the 1LE 2.75" or 3" LS1 aluminum shaft would be better than the stock LT1 shaft...but that one is way better IMO then the V6 2-piece.
The stock V6 is a 2-piece because of the lentgh of the engine. Requires a more drastic angle then the V8 version (2-pieces allows this as there is another joint). However, I have had no problems for like 40K miles with the LT1 shaft.
I got mine from a local guy 5min from my house for $10. Took 10 minutes to install.
93 LT1 is offline
Old 11-28-2005, 03:38 PM
transamtom's Avatar
Sure but the aluminum shaft is in my TA,my Firebird gets the hand me downs from the TA that way I can mod it on the cheap.
I have a set of 35/25 swaybars for the TA so the 'Bird will get the 32/21 combo,when I do the Bilsteins the "Bird will get the 45,000 mile shocks from the TA
Old 11-28-2005, 09:04 PM
IdahoLT1's Avatar
An aluminum driveshaft is also gonna cost some money. Ive seen them go from $300-800.
IdahoLT1 is offline
Old 11-29-2005, 12:36 AM
MarcR94v6's Avatar
(+/-)$10 driveshaft here I come! Along with TB bypass, 180* thermo, and water wetter, I'll be set.
Old 12-05-2012, 11:38 AM
njnick91's Avatar
Talking Re: 3.4 horsepower increase
ive got a 94 5spd
k&n cai
z28 exhuast system
5.7l coil packs
accel 8mm wires (instead of stock 7mm)
bosche copper plugs
lt1 1piece driveshaft
180 thermostat
after doing all this theres a def difference in power from when it was completely stock
njnick91 is offline
Old 01-24-2013, 11:03 AM
bigz28man's Avatar
I think you guys should think about this. The single most thing you can do with out making any modifications to your motor is, gears. Put a nice set of 3:73 gears in there, and your car will feel like you added a crazy amount of horsepower. Unfortunately there is not a whole lot of "bolt ons" ie: cai, exhaust, for these motors. Yes things look good on paper but by the time it gets to the the wheels..not much horsepower left. Yes weight reduction helps, but that can be costly. I heard some guys putting a nice set of flowing heads on but to really use those heads to fullest potential more bolt ons are needed. So again....look into gears.
bigz28man is offline
Quick Reply: 3.4 horsepower increase
