How many miles on your V6?
#31
Re: How many miles on your V6?
Originally Posted by downwithmustang
Hopefully GM want make this mistaken on the 5th gen. What should I do to fix it.
#33
1994 3.4L A4
143,000 miles
Have thus far had to replace: driveshaft, injectors, 2 alternators, head gasket (+ resurface heads), water pump, fuel lines, fuel pump, and a few other things i can't think of at the moment
Needs: oil pan (has gone porous and has a slow leak), find/fix phantom tranny fluid leak, shocks, exhaust...
All told she's cost a lot to repair and keep running (between 5 and 6k), but i swear she gets stronger the more she ages. I can't bear to sell her and pick up a new one!
143,000 miles
#34
Originally Posted by MarcR94v6
If you guys ever have phantom oil leaks, check O-rings in near the dummy distributor.
on a side note 3800s (at least Series 2 or 3) don't have this abomanation.
#41
Originally Posted by MonkeyBoneSS
1998 3.8 Auto
126,000 and still did one hell of a burn out the day before I sold it
The only problem I've ever had was LEAKING T-Tops!!!!!!!!!!!!!!!!!!!!!!
99% of t-top leaks can be fixed for $2 and 5 min of work.
#43
98 3.8 v6
177,206 miles
Automatic
No modification yet. (Don't know where to start that's why I joined)
had the car since 51,000 miles. Transmission went out at 52,000 miles.
No major problems since then. Rattles a little underneath, not sure where from.
177,206 miles
Automatic
#44
99V6 M5
162,xxx miles
Changed rr main seal, fuel pump, ignition coil(warranty), pinion seal, Cat.
Non drivetrain:
Window motors(warranty)
trunk leak(warranty)
Maintenance/other:
PCV, fuel filter, diff fluid, plugs, wires, tires, rotors, pads, radio bulbs.
Car looks like clean and shiney. Basically in great shape, but probably worth around 6k. Alternator is starting to whine, I can see the voltmeter move when I use the headlamps and it will start some whining. About to change plugs again.
162,xxx miles
Non drivetrain:
Maintenance/other:
#45
my car:
97 3.8
97k
M5
Still runs awesome. No problems at all
my dad bought a 94 3.4L at an auction, it had like 280k and still ran just fine. It could have been rebuilt or something though, i have no idea.
97 3.8
97k
M5
