Harmonic Balancer Help
Working on a 1995 3.4 Camaro. I removed the harmonic balancer and made a stupid mistake of not noting exactly where it was at as far as where it lined up with the rest of the pulleys and tensioners. I have the harmonic balancer on and it is tight but I am not lined up with the other pulleys if you where to look at the engine bay from the side.
Does anyone have or know where I could see a side view of the engine to see if this is normal?
Re: Harmonic Balancer Help
Is it pushed all the way back? I have my engine pulled right now and the balancers still on, I can post a pic tomorrow but it won't be till late evening if you want. But if the balancer is on correctly there is just a small gap between in and the engine.
