faild emissions today
ok my readings were
hc 4.9821 limits are 1.200 fail
co 12.6969 limits are 20.0000 pass
co2 408.5252
nox 0.9143 limits 3.0000 pass
every thing passed but the HC..
so what do you think.. i just replaced the coils, plugs, wires..put lucas injector cleaner in her..
check engine light went off. but failed emmisions.. could it be my fuel filter
or dirty injectors help i just bought her and want to enjoy her
v6 3800
co2 408.5252
v6 3800
Re: faild emissions today
HC is unburned fuel.
I think that your catalytic converter is shot.
You say the check engine light was on?
Did you get the codes read?
How many miles on it?
It could also be the O2 sensors have failed or they are not reading properly.
Sent you a PM.
Sent you a PM.
catty converter passed emmisions.... um 165000 miles... i just replaced the 02 the codes i got were left bank 02 evap leak cylinder 6 misfire and egr running at 10%... i replaced 02 cleaned egr tightened gas cap an replaced plugs coils and wires.. now its just a misfire cylinder 6 when i get the car read....
this just started-----> when i rev it in park it starts to cut out at 4000 rpm... it takes a second when i first star it...
i was thinking injectors or and fuel filter
yea just to the eye.... but if it was a coil wouldnt i have multiple misfires???
i seafoamed her too and there seems to be a difference but still hesitates when first strarted... i put bg fuel injector cleaner in her as well... so when that tank is on E im going to put the new fuel filter on then maby see whats up....
sleeperZ96BT
09-09-2015 08:28 AM
RX Speed Works
07-24-2015 02:25 PM
