Bad Cylinder 3.8L
Bad Cylinder 3.8L
My bad luck never fails. Cylinder 3 won't fire. Changed plug, wire, not injector (but I know that isn't the problem). What's the best route to get it fixed? Or should I junk the car, buy new motor? I would love a response to this thread.
Re: Bad Cylinder 3.8L
If it isn't firing and you're absolutly sure you have spark, fuel and air going in then I'd do a compression check. Messed up valve or worn rings could be leaving you with no compression to work with. If you have bad compression then you're looking at a rebuild or replacement. If not check spark (wires, plugs, coils/distributor) and fuel (swap injectors, blow out fuel rail etc) again.
supercharged94Z28
06-02-2015 03:32 PM
