99 firebird V-6 issues
My daughters 99 firebird has a problem while driving, the oil pressure and amp gauges bounce around and the car seems to be missing. No SES is showing. Tried higher octane fuels, and a new fuel filter. The car stubbles worse up hills. Any help would be appreciated.
Re: 99 firebird V-6 issues
I would do a scan to check for codes. The check engine bulb could be burned out. Is it really missing with bad vibrations and all or just having a general loss of power? I had a clogged cat that resulted in power loss that was only really noticeable when you got on it or went up hills. I also had my share of misfire issues due to wires that had melted/cracked and were shorting out.
Hoodshaker
08-27-2002 02:32 PM
CamaroRSguy
10
08-06-2002 04:26 PM
CamaroRSguy
12
07-08-2002 09:39 PM
