99 firebird anti freeze leak
I have a leak of anti freeze from the rear of my 3.8 v-6. Last winter the head gaskets and intake gasket were changed. I had a leak at the waterpump. Fixed that issue. Drips on the driverside at the last too oilpan bolts.Any suggestions. Thanks
Re: 99 firebird anti freeze leak
Have you gotten it fixed yet? If you dont want to replace the gaskets again I would try some Bars Leak head gasket sealer. It worked for my leak although I had to try it a couple times and run it through much longer than it said on the bottle. If you run it through with water it seems to have more effectiveness. I ran it through with water for about a week driving around, then finally flushed it good and added 50/50 dex cool and water. 3000 miles and still no leak.
charchri4
04-14-2015 06:40 PM
warmeck
03-01-2015 08:47 PM
CLEAN
08-31-2002 03:27 PM
