Weird Voltage Surge problem....Help
Ok, sometimes but not always, When im slowing down i put the car in neutral (5spd manual) and hit my brakes, the lights dim and my volts drop and then they`ll come back up. Sound like an alternator maybe to you guys?
Re: Weird Voltage Surge problem....Help
Originally Posted by deadmeat2004
just your car using the juice. Dont worry. Unless its really really bad.
just incase, check/clean teh battery terminals, and if you're **** about it, check out to make sure all your grounds are good and clean, but this shouldn't be necessary
Mine does the same thing. Brand new red top Optima and a new alternator later Ive learned that unless you want to drop 200 on a higher watt amp, the problem will always exist. Luckily I needed these parts or I would have just lived with the problem and never known. Makes having a system a PITA also...
Nayr
03-03-2023 08:34 PM
08-07-2015 01:26 PM
