94 3.4L camshaft removal help
Old 07-19-2012, 11:42 AM
thomaslea1's Avatar
Putting a 94 3.4 into a 73 MG and doing a refresh. Down to getting the cam out. Block is bare except for the cam and the "plug" thing where the distributer used to go. I assume I have to get this out first. HOW? The looks to be a welch plug in the top of it. Do I need to pull that. Yes, the clamp is off and I can turn it easily. Just can't pull up.
Second: This engine does not have roller lifters. Is it supposed to if it's a 94? How elae would I ID it. It came from a recycler who pulled it from a 94 Camaro.
Thanks a lot.
Tom
thomaslea1 is offline
Old 07-19-2012, 01:52 PM
Dave89IROC's Avatar
If the clamp is off the oil pump drive, pull the entire thing up, or tap a scraper under it, its ok if you scratch the bottom, it is sealed with an o-ring on the body, leave the weltch plug alone
Dave89IROC is offline
Boss002
01-20-2016 12:17 PM
Dark Zeiro
07-19-2015 08:25 AM
07-17-2015 02:47 PM
ducttape1975
07-10-2015 06:29 PM
mrwz28
07-08-2015 09:11 PM
Quick Reply: 94 3.4L camshaft removal help
