94 z28 vs. 96 mustang GT??
hey you guys i have a 94 camaro z28....and i have the non performance rear end with the 2.73 gears and my friend has a stock 5 speed 96 mustang GT and i was wondering if anyone with a z28 of the same kind raced any mustangs like this both bone stock??
i use to own a 97 gt (exactly the same as the 96gt)... regarding the previous comment on a lt1 will rape a 4.6 sohc.. that is incorrect for sure.. the 99-04gt's come with a pi sohc (power improved SOHC) which has a lot of power.. they can be run into the 13's stock i have heard as low as 13.7 from a local guy...
the 96-98gt's however have what is called npi heads/cams/intake (non performance improved) so they only have 225 isntead of the 260 from the pi h/c/i.. my stock 97gt i was only able to run 15.1.. a catback and cai and i ran 14.7... even still that is not quick enough to keep up to a lt1..
so:
lt1 > npi 4.6 sohc
so:
lt1 > npi 4.6 sohc
my signature yes says 3.42 i have bought the 3.42 gears but yet to put them on i dont know if i'm not supposed to do that but i wanted to race my friend bone stock against bone stock before i actually did the gear swap and put my mods on
Even on the newer 260hp one's they are by no means a beast (obviously) but half the time they are 5 speeds and no one can drive lol. ( applies to all standards)
Just a little side note this post "might" belong in the lounge.
Depends on what you consider fast, coming from an f-body owner they are not fast. They are not your mothers minivan either (unless its a 96-98 ) But yeah, the typical GT is nothing special.
so:
lt1 > npi 4.6 sohc
so:
lt1 > npi 4.6 sohc
