upper control arm bushing
Old 11-06-2014, 04:06 PM
  #16
nikko's Avatar
Re: upper control arm bushing
Yes their instructions were almost identical to the one you posted
nikko is offline
Old 11-07-2014, 12:34 PM
  #17
nikko's Avatar
sorry to be a bother but these prothane bushings have no slots I'll try to download picture Is the slot location what you are talking about or some thing else.
nikko is offline
Old 11-07-2014, 03:01 PM
  #18
nikko's Avatar
Unhappy Re: upper control arm bushing
Well another set back took the lca to shop to get ball joint pressed and the messed it up by putting a big circular gouge on the lca Hate to say it but I need a break
nikko is offline
Old 11-07-2014, 03:42 PM
  #19
Ricardo's Avatar
I did mine about a year ago and found that the lower ball joints were oversized when compared to the ones that came with the car.
The difference in diameter was .017"
I had to turn them down in order to be able to press them in place.
Good luck with your rebuild
Ricardo is offline
Old 11-07-2014, 05:08 PM
  #20
nikko's Avatar
Thanks ricardo you have a nice ride
nikko is offline
Old 11-09-2014, 07:06 PM
  #21
nikko's Avatar
Smile Re: upper control arm bushing
Got my replacement lca back from shop yesterday w/new ball joint pressed in. Wondered why they couldn't do it right the first time. Now to get the bushings back out and restart that Project
nikko is offline
Old 11-21-2014, 07:54 PM
  #22
nikko's Avatar
Exclamation Re: upper control arm bushing
Took my strut assy to shop to have springs compressed and new shocks put in . found out the spring was broken so got a new set of moog springs. But the guy forgot to replace the cover sleeve on the shock.Is this something that I have to redo or go with
nikko is offline
Old 11-30-2014, 11:53 AM
  #23
Ricardo's Avatar
There is a bump stop inside the front shock sleeve IIRC.
Someone correct me if wrong.
Ricardo is offline
Old 11-30-2014, 06:00 PM
  #24
You are correct.... the sleeve includes the bump stop. I managed to move the stock sleeve to my QA1 shocks when I installed them.
I'm still trying to understand how the spring could be broken, and not be obvious, just from looking at the coil-over spring/shock assembly (it is not a "strut"). You'd have two pieces of spring rattling loosely on the shock.
Injuneer is offline
Old 12-01-2014, 07:44 PM
  #25
nikko's Avatar
Wink Re: upper control arm bushing
Yes I guess I got duped into believing the spring was broken .I did take it apart with the loaner tool from A zone and replace the sleeve with the bump stop .I guess with 129,000 miles it didn't hurt to change the springs. Got it all together and put away for winter . And I'll get it aligned in the spring since I have now put storage insurance on it. Thank you guys for all your help
nikko is offline
Old 04-19-2015, 08:27 PM
  #26
nikko's Avatar
Well I'm back .Have gotten the Camaro out and aligned and all moving parts are new .Took it out for a ride .Don't really know what I was expecting but I figured it would ride nicer and tighter. Man this thing now drives like a tank Maybe the bushing weren't what I needed to make it ride better. Every bump is now amplified and I just don't like the ride Put a hundred miles on it yesterday and it may ride a little better but hope I'm not just getting used to it .any comments appreciated. Thanks Richard
nikko is offline
Old 04-19-2015, 09:03 PM
  #27
Poly will feel more solid than worn out rubber, but from my experience, not all that harsh.
The other things that can affect firmness of the suspension are the spring rate and the firmness of the shocks. What springs did you get, what shocks?
If you expected all these new parts to replicate the soft, sloppy ride of the old, worn out components, your expectations were not realistic.
Injuneer is offline
Old 09-06-2015, 05:05 PM
  #28
Not Dave's Avatar
I'm guessing Nikko's issues were resolved with more miles and some break-in of the new components.
He did what I want to do but thinking I'd go with new rubber instead of poly bushings. The shocks I want are the SLP-valved Bilstein's.
Not Dave is offline
Koby
06-28-2015 04:46 PM
dbrockma
02-16-2015 02:56 PM
Jason Short
01-19-2015 06:34 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: upper control arm bushing
