Trough Wander
Old 06-24-2014, 04:00 PM
Z4Ccoupe's Avatar
Trough Wander
The SLP suplimental owner's manual that came with the Camaro SS's in '96 warned that the cars are subject to trough wander. Has anyone experimented with front end suspension settings (camber, caster, toe in/out) to find which suspension settings minimize the effect?
Z4Ccoupe is offline
Old 06-25-2014, 12:05 PM
Super Moderator
JakeRobb's Avatar
Re: Trough Wander
I'm not familiar with the term "trough wander," but I think it's the same as tramlining, which is where the contour of the road can steer the car.
Not a direct answer to your question, but I'm guessing the factory settings are pretty ideal in that regard.
I have found that tires make a huge difference. In general, cheap tires will tramline more. My current tires (Continental ContiExtremeContact DW in 275/40/17) are MUCH better than the Goodyears I had before these.
JakeRobb is offline
Old 06-25-2014, 12:25 PM
Re: Trough Wander
Can also be sensitive to tire inflation pressure.
Tire Rack has some good info:
http://www.tirerack.com/tires/tirete....jsp?techid=47
Injuneer is online now
Old 06-25-2014, 07:41 PM
Z4Ccoupe's Avatar
Re: Trough Wander
Thanks guys. All of that makes sense re: tire brands, tire wear etc. It seems logical that increased caster would be a help reduce the effect, somewhat. When I was road racing, we always wanted negative camber and a small bit of toe out. It made the car turn in better. But those characteristics probably make tramlineing worse. I drove someone else's 97 SS the other day and it seemed to have very little tramlineing compared to mine. It had the OEM tires with 19K miles on them. OTOH, a friend's 2002 WS6 has always been really bad and it has had numerous front end alignments and several sets of tires in it's 130k mile history. Just trying to figure something out how to make it more manageable.
Z4Ccoupe is offline
Mitch666
10-10-2003 10:17 PM
carr_z28
09-27-2003 11:25 AM
br1ev8
06-25-2003 12:22 PM
keven
Advanced Tech
01-25-2003 11:11 AM
LT1Brutus
10-12-2002 04:38 AM
Quick Reply: Trough Wander
