Tie Rod End Replacement - Some Quick Questions (mostly grease-related)
Hi All,
I've had my 2000 Z28 Camaro since it was new. Since then, I've had two kids and now I'm desperately trying to keep my beloved Camaro. One of the ways I have been doing this is by doing a few of my own simple repairs where I can. But so far my experience with doing my own repairs has been an alternator replacement (twice), and the front brakes (including replacing the caliper bracket and pins).
Now, I find myself needing to replace the driver's side outer tie rod end. The tire place said they couldn't do an alignment until it was replaced. But I didn't want to pay them $300 to do it! So here I am.
I realize I'm "cheaping out" here, but I have gotten ahold of a Duralast replacement tie rod end. And it comes with the thingamabob for applying grease with a grease gun. So, here are my questions. . .
Thanks!
Hurin
- Does it come pre-lubricated? (so I don't need to buy a grease gun and do it now)
- If not, since my next stop after replacing the tie rod end will be the tire shop for new front tires and an alignment, is it reasonable to expect/request that they lube the tie rod end while they're aligning it?
- If no to both prior questions, any tips on procuring a grease gun, and applying the grease? Are they just dime-a-dozen and you just give it a squeeze until the boot expands?
Thanks!
Hurin
Re: Tie Rod End Replacement - Some Quick Questions (mostly grease-related)
If it has a zerk fitting, it needs to be greased.
I wouldn't count on an alignment shop checking to see if the fittings were adequately greased.
All you need is a mini grease gun using cartridges, available at most auto parts stores. Here's an example:
Grease Gun with 3 Oz. Grease
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
If you don't already have the best 2000 F-body service manual available, you can get one here for free:
https://www.mediafire.com/?40mfgeoe4ctti
Well, just put in the replacement tie rod end.
All went pretty smoothly. Now that I know what I'm doing, could easily get it done in half an hour (or less).
I'm not sure about how much grease I used. I gave the grease gun four or five pumps and I think I saw the boot plump slightly. But I started to feel some resistance and didn't want to overdo it. I hope that's okay.
oldschool
02-09-2016 09:21 PM
