Subframe connectors, needed? Kind?
Old 04-21-2013, 10:05 AM
Greg88's Avatar
Hey guys, I'm puttin in a new motor around 400 rwhp. The guy I bought the motor from highly suggested me to get some, is it truly needed?? Might go to the strip but probably not anytime soon. Also, got a t-top car, lowered. What is the best kind? I was looking online at some, would a t top be considered full top car? Don't want some connectors that hang real low on my car, since it is lowered! Thanks guys!
Greg88 is offline
Old 04-21-2013, 02:07 PM
Re: Subframe connectors, needed? Kind?
I think they are a good idea. I ran a bolt-on LT1 with a 125-shot of nitrous (t-top car) and didn't opt for SFC's. Didn't do any damage that I could tell. But when I went to the stroker/300-shot setup (800HP/.800lb-ft) I had a chrome moly custom roll bar installed, and had them install chrome moly SFC"s that are integrated with the roll bar. The car stiffened up a lot. Like most cars with SFC's, jack up a wheel, and the entire side of the car comes off the ground.
Mine tend to hang a bit low, because of the way they set them up, but no problems at stock ride height. The ready-make SFC's from shops like Spohn Performance tuck in very tight behind the rocker panels.
Tubular Subframe Connectors | 1993-1997 F-Body Camaro & Firebird
Injuneer is offline
Old 04-21-2013, 07:19 PM
Greg88's Avatar
Ok perfect! You think the chrome moly ones are over board for my set up? Mild steel be ok?
Greg88 is offline
Old 04-21-2013, 09:59 PM
You don't save much weight with only chrome moly SFC's. I did chrome moly because of the roll bar, and saved about 40#. The welding is a bit more difficult as well, compared to mild steel.
Injuneer is offline
Old 04-28-2013, 08:25 PM
Greg88's Avatar
Now installing them, is it ok to just weld them in on a two post lift with the suspension and everything hanging? Or does it have to have the body weigh on the car? A buddy of mine said his 04 cobra has to have the weight of the car on the suspension, not sure which is right?
Greg88 is offline
Old 04-28-2013, 09:06 PM
jloshotz's Avatar
Do it on a four post lift if you have access to one, you want the car at ride height and weight on the wheels
jloshotz is offline
Old 05-01-2013, 08:30 AM
rv93's Avatar
sorry to thread jack, but are there any issues doing work on the underside of the car, like say removing the exhaust with the sfc in there? i want to get weld in ones for the extra strength, but i want to keep my options open...
rv93 is offline
Old 05-01-2013, 08:37 AM
jloshotz's Avatar
Zero interference with the straight SFC'S on non-convertible versions. Some of the stronger multi point supports (as in double diamond, or SFC's for verts) are a different story I'm thinking
jloshotz is offline
Old 10-02-2013, 12:15 PM
87Aerocoupe's Avatar
I have the SLP 3 point weld in sfc and they really stiffen up the car. UMI also makes the 3 point style.
87Aerocoupe is offline
Old 11-26-2013, 09:28 AM
SteveC's Avatar
Thumbs up Re: Subframe connectors, needed? Kind?
I also have the SLP 3 point sub frame connectors, and mine are in the bolt on category. During the installation the mechanic used "red" Loctite on the bolts, as I am not planning to ever uninstall them. I also had a "U" brace installed to tie in the connecters at the front most point.
Sub frame connectors keep the body from flexing during hard acceleration, the damage that can be seen is usually on the rear fenders in front of the rear wheels, you will see "rippling" of the fender when looking down the side of the vehicle.
My 2001 Z28 (Sara) is stock motor that dyno's @: 298RWHP/325RWTQ (@5800 RPM). My point? EVERY F body profits from the installation of sub frame connectors.
SteveC is offline
Parts Wanted
03-17-2015 11:24 PM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
slothgrant
08-22-2002 03:01 PM
mjcent922
07-27-2002 12:42 PM
Quick Reply: Subframe connectors, needed? Kind?
