Rear end thumping
Old 06-17-2010, 02:30 AM
A15DollarBurger's Avatar
Rear end thumping
Hi All,
Whenever I go over bumps, there is this thumping sound somewhere around the rear of the car. It also happens sometimes when I get in the car too...
I have been under the car 3 times to check/fix the problem but to no avail. My best guess was the torque arm bolts were loose but I tightened them as hard as I could, same problem and I'm no pro when it comes to suspension.
Is there a specific place I should check? LCAs? Panhard rod? Has anyone else have this problem?
All parts are stock except for the Spohn adj TA. Also has new(ish) rear shocks.
Was thinking of replacing the bolts from the relocation bracket of the TA (scraped it a couple of times with the horrible road conditions here) but wanted to be sure...
Thanks,
A15DollarBurger is offline
Old 06-17-2010, 04:45 AM
jasonface's Avatar
The LCA's and panhard rod both have bushings that can wear out, so yes, check them
jasonface is offline
Old 06-17-2010, 12:02 PM
n2ceptor's Avatar
Have you check the exhaust system???
n2ceptor is offline
Old 06-17-2010, 03:20 PM
firebirdStud's Avatar
something dumb.. but how about the spare tire? mine came loose last year and it drove me nuts figuring out the noise!
firebirdStud is offline
Old 06-18-2010, 01:25 PM
Hello,
Thanks for the responses, I will check the bushings of the control arms.
I thought that it might have been the exhaust but the thumping is still heard whenever I jack the car up with the rear end unloaded.
It's not the spare tire because I took it out.
If it is the bushings, I will just replace the entire part... should I get adjustable parts although I don't plan to lower the car?
Thanks,
Old 07-05-2010, 08:55 PM
Update:
I replaced the LCAs, PHB, and rear sway bar, all UMI stuff. When I took off the stock LCA, I heard the same thumping when the rear end moved slightly forward and backwards. After the new parts were in, smame thumping, but less frequent now. I have no idea now what it is.
Any suggestions?
Thanks,
Old 07-06-2010, 02:26 PM
OBE1 95Z28's Avatar
Check the U-joints on your drive shaft as it moves around when you move the rear end.
OBE1 95Z28 is offline
Old 07-13-2010, 11:16 AM
I will check the u-joints. It does seems that it thumps/clunks less when I accelerate, but it may just be because I can't hear it over the engine. Lol at this point I'm so used to it that I know WHEN it'll thump, but i guess that's better than having random sounds.
Thanks,
Old 07-13-2010, 11:42 AM
RUDEDOG's Avatar
Is the Spohn ADJ TA a chassis mount? If so I had the same thump with mine. I had a Spohn ADJ TA chassis mount with poly bushing. Replaced it with a BMR ADJ trans mount type with poly bushing. Thumping gone.
RUDEDOG is offline
Old 07-16-2010, 02:44 AM
Yes it is! Did you know exactly what part was making it thump? Front rotator mounts? just added grease to them to see if it would stop, it didn't.
Thanks,
Old 07-16-2010, 04:38 AM
RUDEDOG's Avatar
I tried that too. The only way I could get it to stop was changing to a trans mounted piece. It gave it some heavy weight to mount to instead of a flexable floor pan.
RUDEDOG is offline
10-31-2016 11:09 AM
blac94Z
03-02-2015 06:03 PM
Chet1185
02-04-2015 09:51 PM
jcamaro95lt1
01-24-2015 08:21 AM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
Quick Reply: Rear end thumping
