Rear spring mount
Old 05-10-2015, 06:37 AM
KYWes's Avatar
Rear spring mount
Ok, so I was doing some work on the back of my car and noticed that there is no rubber isolation mount under the rear coil springs of my car. It looks like the springs are just fitting around a small raised piece on top of the axle.
Is this right or have I lost a mount for my springs?
KYWes is offline
Old 05-10-2015, 06:47 AM
FirstYrLS1Z's Avatar
Re: Rear spring mount
yes,it is right,the upper end of the spring has the isolation mount.
FirstYrLS1Z is offline
Old 05-10-2015, 10:47 AM
You can download a free copy of the 94 factory manual, good reference for questions like this:
LINK: 4TH GEN SERVICE MANUALS - Firebird Nation
Or, if you don't want to do that, Nalley has the factory parts diagrams:
SUSPENSION/REAR. Fits: Camaro, Firebird, FORMULA, TRANS AM | Nalley Buick GMC Brunswick
Injuneer is offline
Old 05-10-2015, 01:55 PM
KYWes's Avatar
Good to know. Thanks
KYWes is offline
Old 05-12-2015, 04:04 AM
KYWes's Avatar
I'm going to replace the rear springs on my '95 Z28. I see they're not coil overs. Any tips or gotchas I should know? Is it as simple as compress the spring, remove and reverse with new spring?
KYWes is offline
Old 05-12-2015, 05:29 AM
Don't even need to compress the spring. Support chassis by jack stands, unbolt lower shock bolt, lower rear axle slowly. Springs will fall out.
Injuneer is offline
Old 05-12-2015, 06:19 AM
KYWes's Avatar
Excellent! I'm replacing the shocks so I can do it all at once.
KYWes is offline
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
Jazsun
12-29-2014 12:14 PM
wytblur
03-02-2003 03:40 PM
Quick Reply: Rear spring mount
