New Pics of my C5 Brake Conversion
Old 06-09-2006, 03:46 PM
68z28's Avatar
Just finished my C5 front brake conversion. There is absolutely no comparison to the ol' LT1 Brakes. I got everything but the calipers from Tobin at www.Kore3.com
These are 18" wheels they are filling up, not 17's
Before
After
68z28 is offline
Old 06-09-2006, 05:56 PM
mudbone's Avatar
Re: New Pics of my C5 Brake Conversion
Man, what a difference! Those shoes must really haul you in.
mudbone is offline
Old 06-09-2006, 06:17 PM
97WS6Pilot's Avatar
Those lt1 brakes look like kids toys compared the those C5's. Which pads did you choose?
97WS6Pilot is offline
Old 06-09-2006, 11:42 PM
68z28's Avatar
I went with the stock AC Delco ceramic pads. I needed the anti-rattle clips and these were my best option.
68z28 is offline
Old 06-10-2006, 11:16 AM
97WS6Pilot's Avatar
I went with the Z06 pads and they are dusting real bad. How is the dusting with the ceramics?
Old 06-10-2006, 12:45 PM
91Z-28's Avatar
I went with ceramics on my C5 setup, dusting is very minimal.
91Z-28 is offline
Old 06-10-2006, 02:20 PM
IgorT.455/406's Avatar
It looks like a nice setup.
How do you like those C6 wheels and do they fit well? What size rims/rubber?
Once I go with 18s I think I'm gonna go with the C5 Z06 setup, Slotted and Cross drilled with red calipers and ceramic pads.
What about the rear? Are lt1 calipers the same as the z06 calipers? Seems that rear prices are way less. If so, can I just run the same Slotted and Cross drilled rotors in the rear with matching ceramic pads w/lt1 calipers? Or should I just upgrade to rear Z06 red calipers?
Thanks!
My car is red, would match well.
IgorT.455/406 is offline
Old 06-10-2006, 05:40 PM
stereomandan's Avatar
Looks good. I also bought the AC Delco pads, but only used the springs out of them. I used the AC Delco springs, but put Hawk HPS pads on. Cost me a little more, but I figured with all the money spent on the brake conversion, I didn't want to skimp on pads especially since I was putting HPS pads in the rear too.
Dan
stereomandan is offline
Old 06-10-2006, 06:57 PM
68z28's Avatar
97 WS6 Pilot: The brake have been on for about 5 days and I have noticed hardly any dusting.
IgorT: The wheels are 18x9.5 at all corners. I love the C6 design, I wish they had a lip on them, but when their moving it appears to have a big lip because of that inward curve behind the spokes. I bought them off ebay from Moore9111(something like that). The tires are 275/35/18 's. The rear C5 brakes are not even close to stock LT1. They use 12" rotors compared to the 11" on LT1's. I'm not sure if there is a diffrence between LS1 and C5 though, they might be the same. I'll be redoing the rear as soon as my current pads wear out. There is no mechanical diffrence between C5 and Z06 brakes, only a red powerdercoat.
stereomandan: I wanted Hawk HPS pads too but I also needed the clips. I plan on reusing the clips next time with HPS pads.
68z28 is offline
Old 06-10-2006, 08:34 PM
Thanks.
One other question...with C5 rear brakes, what is the smallest wheel one can run?
Thanks.
Old 06-10-2006, 10:20 PM
WinkleTheMoose's Avatar
17" I believe
WinkleTheMoose is offline
Old 06-10-2006, 10:30 PM
Yes, the smallest diameter is 17", but you also have to make sure the caliper clears the spokes of the rim. There is a template you can use to check. My 17" SS rims clear fine.
Dan
Old 07-26-2006, 09:13 AM
PoorMan's Avatar
So what do you use for a spare? or do you? I am in on the BB bracket GP going on now and was wondering what sort of spare to buy. I guess a C5 spare?
PoorMan is offline
Old 07-26-2006, 11:53 AM
I don't use a spare. If it goes down, it's getting towed.
Dan
RUENUF
05-25-2016 08:10 PM
Fastbird93
04-09-2016 07:01 PM
RUENUF
03-13-2016 03:39 PM
HarleyZ28
10-05-2015 06:23 AM
Queens94z28
12-20-2014 09:11 PM
Quick Reply: New Pics of my C5 Brake Conversion
