tech article
Old 07-03-2009, 03:41 PM
pj97ragtop's Avatar
tech article
is their one on how to change shocks on a 97 camaro front & rear thanks
pj97ragtop is offline
Old 07-03-2009, 04:14 PM
cobra12's Avatar
take wheel off. loosen shock bolts. remove shock. insert new shock. tighten bolts. put wheel on.
cobra12 is offline
Old 07-03-2009, 04:17 PM
n2ceptor's Avatar
MIght check Shoebox's tech page..... I dont have access now..
n2ceptor is offline
Old 07-03-2009, 04:20 PM
pj97ragtop's Avatar
ok
that is good for the rear how about the front 2 places that i called wanted 3 to 4 hours labor for the fronts rears are no problem thanks again
Old 07-03-2009, 05:30 PM
cobra12's Avatar
nothin on shoebox.
this isn't the best but...
http://www.ehow.com/how_4484927_repl...vy-camaro.html
I'll try to find something with pics.
cobra12 is offline
Old 07-03-2009, 05:35 PM
n2ceptor's Avatar
https://www.camaroz28.com/forums/sho...ghlight=remove
n2ceptor is offline
Old 07-03-2009, 05:40 PM
cobra12's Avatar
you win. the first link doesn't work though.
cobra12 is offline
Old 07-03-2009, 10:46 PM
Injuneer has directions on his site.
shoebox is offline
Old 07-04-2009, 08:38 AM
Its a bit more complicated than that on the 4th Gen's unequal A-arm coil-over front suspension.
My writeup does not have any photos attached, but most people have found it helpful. Be sure to read (and follow) the part about marking the relationship of all the parts - upper spring/shock mount, spring and lower shock mount - or its not going to go back into the holes in the shock tower for the upper spring/shock mount.
http://www.injuneer.com/HALEibch.html
Injuneer is offline
Old 07-04-2009, 02:48 PM
pj97ragtop's Avatar
thank you
thanks for the help and pictures
Old 07-04-2009, 05:35 PM
bluz28's Avatar
Thumbs up
Here's another one.
It's #9, #10 in the F-body Howto's
http://www.ls1howto.com/index.php?category=0
bluz28 is offline
93 RedBird
11-15-2015 08:24 AM
Fatdog2
09-16-2015 11:04 PM
mark0006
09-14-2015 12:35 PM
RX Speed Works
09-11-2015 03:31 PM
Quick Reply: tech article
