How to Change Rear Disc Brakes
Old 11-23-2005, 09:40 AM
DontMixWithRice's Avatar
Im looking for a good how to site that can tell me what to look out for when changing the rear disc brake pads and rotors.
Can any of you give a few pointers?
DontMixWithRice is offline
Old 11-23-2005, 11:19 AM
NEWBIE T/A's Avatar
Thumbs up Pretty Much The Same as the Fronts !
So, This should be a good guide for you.
Good Luck !
Britt
NEWBIE T/A is offline
Old 11-23-2005, 11:47 AM
Re: How to Change Rear Disc Brakes
linky no workie.
Old 11-23-2005, 11:52 AM
NEWBIE T/A's Avatar
Exclamation Their server seems to be off & on today ...
Try it again in a little while.
Their main link is :
http://www.installuniversity.com/
Click on LSX vehicles, then go to install articles.
Lot's of good info.
Britt
Old 11-23-2005, 11:55 AM
Thanks for the help, Britt.
Old 11-23-2005, 03:47 PM
camaro777tom's Avatar
Removal:
1. Remove lug caps
2. Remove lug nuts
3. Jack Up car
4. Remove Tires/Rims
5. Support Rear with jackstands
6. Remove 2 bolts holding caliper/bracket assembly
- bolts are 5/8" I think and the heads of the bolts are on the backside of the axle
7. Remove caliper assembly from rotor and support (Do not let it just hang there)
8. Remove pads from caliper assembly (they slide out)
- may want to pop the brake fluid cap and remove some fluid from the resivior before proceeding
9. Use a large c-clamp to depress caliper plunger
9. Remove Rotor (may need a hammer and a few good whacks if old)
Install:
10. Replace rotor
11. Place new pads in caliper
- these should have a spring on one end. You depress the spring in the groove and slide the pads into slots in the calipers (the pad with the extra tabs on the ends faces the main caliper piston
- you may want to add some specific brake quieting grease and/or shims between pads and caliper
12. Slip caliper with pads onto rotor (if it doesn't fit remove the pads and depress the piston using the c-clamp more)
13. Re-install 2 caliper assembly mounting bolts
14. Raise vehicle and remove jackstands
15. Re-install wheels/rims/lugs
16. Lower vehicle and torque lugnuts
17. Re-install covers
18. Refill brake fluid to proper level
19. Re-install brake fluid cap
20. Start car and pump brakes a few times
Should be good to go!
camaro777tom is offline
Old 11-23-2005, 03:54 PM
OBE1 95Z28's Avatar
If your brake fluid hasn't been changed in a while, good time to change/bleed the brake system. Use brake cleaner to get grease/oil off the rotors prior to remounting the wheels; don't get grease or oil on the brake pads. New pads and rotors need to be seated or seasoned to get the best performance out of the system.
OBE1 95Z28 is offline
Old 10-13-2006, 09:20 PM
Oxygen454's Avatar
I have two questions
1) When I push on my brakes at a stand still or coming to a stop they make a wierd squishing or springy noise and you can feel it a bit in the brake pedal. What the heck is this? I didnt silicone the pads when I put them back on, could that affect the install and should I silicone all the brakes?
2) How do you know when a disk is warn and has to be turned or is beyond turning?
Thanks!!
Oxygen454 is offline
Old 04-02-2009, 08:17 PM
Paul94Z28's Avatar
LT1 Rear Caliper bolt
Do I need to buy a new pair of rear caliper bolts for my LT1 brakes?
I never have, and just noticed the manual says to replace it.
Paul94Z28 is offline
Old 04-02-2009, 08:18 PM
Paul94Z28's Avatar
old
I just noticed how old this thread was, ouch
Old 05-02-2009, 11:37 PM
Oxygen454's Avatar
I havent replaced mine yet but its good practice. They tend to rust away after time and sometimes the head gets mangled making it hard to remove the bolts.
F'n1996Z28SS
08-23-2023 11:19 PM
dale3in98
02-14-2015 12:18 PM
FredM
12-18-2014 01:40 PM
07-04-2005 05:00 PM
Quick Reply: How to Change Rear Disc Brakes
