Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 F-Body Technical Discussion > 1967-2002 Specific Technical Discussion > Suspension, Chassis, and Brakes
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 11-23-2005, 09:40 AM   #1
How to Change Rear Disc Brakes
Im looking for a good how to site that can tell me what to look out for when changing the rear disc brake pads and rotors.
Can any of you give a few pointers?
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
1995 Really Stock (RS) Camaro---now featuring LT1 powah!
DontMixWithRice is offline   Reply With Quote
Old 11-23-2005, 11:19 AM   #2
NEWBIE T/A's Avatar
Thumbs up Pretty Much The Same as the Fronts !
So, This should be a good guide for you.
Good Luck !
Britt
__________________
'99 T/A
Best 13.071 @ 104.92
Now own '99 SS # 2073 !
12.786 @ 107.01 Now w/ the 100K© mod !
NEWBIE T/A is offline   Reply With Quote
Old 11-23-2005, 11:47 AM   #3
Re: How to Change Rear Disc Brakes
linky no workie.
__________________
Old 11-23-2005, 11:52 AM   #4
NEWBIE T/A's Avatar
Exclamation Their server seems to be off & on today ...
Try it again in a little while.
Their main link is :
http://www.installuniversity.com/
Click on LSX vehicles, then go to install articles.
Lot's of good info.
Britt
Old 11-23-2005, 11:55 AM   #5
Thanks for the help, Britt.
__________________
Old 11-23-2005, 03:47 PM   #6
Removal:
1. Remove lug caps
2. Remove lug nuts
3. Jack Up car
4. Remove Tires/Rims
5. Support Rear with jackstands
6. Remove 2 bolts holding caliper/bracket assembly
- bolts are 5/8" I think and the heads of the bolts are on the backside of the axle
7. Remove caliper assembly from rotor and support (Do not let it just hang there)
8. Remove pads from caliper assembly (they slide out)
- may want to pop the brake fluid cap and remove some fluid from the resivior before proceeding
9. Use a large c-clamp to depress caliper plunger
9. Remove Rotor (may need a hammer and a few good whacks if old)
Install:
10. Replace rotor
11. Place new pads in caliper
- these should have a spring on one end. You depress the spring in the groove and slide the pads into slots in the calipers (the pad with the extra tabs on the ends faces the main caliper piston
- you may want to add some specific brake quieting grease and/or shims between pads and caliper
12. Slip caliper with pads onto rotor (if it doesn't fit remove the pads and depress the piston using the c-clamp more)
13. Re-install 2 caliper assembly mounting bolts
14. Raise vehicle and remove jackstands
15. Re-install wheels/rims/lugs
16. Lower vehicle and torque lugnuts
17. Re-install covers
18. Refill brake fluid to proper level
19. Re-install brake fluid cap
20. Start car and pump brakes a few times
Should be good to go!
__________________
http://images.cardomain.com/member_i...9/398635_1.jpg
'94 Z28, wings west body kit, VFN 4" Cowl hood, RK Sport sport wing, K&N FIPK, TB Bypass, 160 therm, LT4 KM, Hooker cat back, FLP Stage 4 transmission, T-top Conversion, 3.23 gears, Auborn posi, much more to come . . .
http://members.cardomain.com/camaro777tom
camaro777tom is offline   Reply With Quote
Old 11-23-2005, 03:54 PM   #7
OBE1 95Z28's Avatar
If your brake fluid hasn't been changed in a while, good time to change/bleed the brake system. Use brake cleaner to get grease/oil off the rotors prior to remounting the wheels; don't get grease or oil on the brake pads. New pads and rotors need to be seated or seasoned to get the best performance out of the system.
__________________
2010 2SS RS IOM M6
1995 Z28 - M6, Blown, intercooled and nitrous injected! Featured in Camaro Performers Magazine, May '05
OBE1 95Z28 is offline   Reply With Quote
Old 10-13-2006, 09:20 PM   #8
Oxygen454's Avatar
Send a message via MSN to Oxygen454
I have two questions
1) When I push on my brakes at a stand still or coming to a stop they make a wierd squishing or springy noise and you can feel it a bit in the brake pedal. What the heck is this? I didnt silicone the pads when I put them back on, could that affect the install and should I silicone all the brakes?
2) How do you know when a disk is warn and has to be turned or is beyond turning?
Thanks!!
__________________
~1996 Z28 Camaro 350 LT1~
Mods: K&N cold air intake, Flowmaster, more to come!
Oxygen454 is offline   Reply With Quote
Old 04-02-2009, 08:17 PM   #9
Paul94Z28's Avatar
Garage
LT1 Rear Caliper bolt
Do I need to buy a new pair of rear caliper bolts for my LT1 brakes?
I never have, and just noticed the manual says to replace it.
__________________
Paul Steepe
Street Lethal Performance
www.streetlethalperformance.com
1994 Camaro Z28 M6
Paul94Z28 is offline   Reply With Quote
Old 04-02-2009, 08:18 PM   #10
Paul94Z28's Avatar
Garage
old
I just noticed how old this thread was, ouch
__________________
Paul Steepe
1994 Camaro Z28 M6
Old 05-02-2009, 11:37 PM   #11
Oxygen454's Avatar
I havent replaced mine yet but its good practice. They tend to rust away after time and sometimes the head gets mangled making it hard to remove the bolts.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
