How to change rear brakes?
Old 05-25-2012, 08:20 PM
97z28k&N's Avatar
Alright, this is driving me insane. Either I am massively overlooking something or there's more to it, but I can't figure out how to get to the bottom calliper bolt. There's a spring covering it with a plate around it. I wish I had a picture for you....
I have taught myself how to do everything from front brakes and rotors to resealing the intake manifold, but this just has me stumped.
brake callipers are stock 1997.
97z28k&N is offline
Old 05-25-2012, 08:29 PM
jloshotz's Avatar
Once you take the top bolt out, the bottom should be a pin, and you can just swing the caliper right off of the rotor
jloshotz is offline
Old 05-25-2012, 10:03 PM
97z28k&N's Avatar
Re: How to change rear brakes?
REALLY?!
Is there enough room to get the pads in and out/ compress the calliper??
97z28k&N is offline
Old 05-26-2012, 08:53 AM
jloshotz's Avatar
The pads should pretty much fall right out, then you can depress the piston, new pads, swing it over and down, top bolt back in. That's how mine went
jloshotz is offline
Old 05-26-2012, 08:58 AM
97z28k&N's Avatar
Thanks! I appreciate the advice. I'm going to go try it now!
97z28k&N is offline
Old 05-26-2012, 09:18 AM
You can even depress the piston with a c-clamp before you swing the caliper outwards and remove the pads. Make sure there is room in the master cylinder for the brake fluid that will be forced into it when you depress the piston. Makes a real mess, and eats the paint off in seconds if it overflows.
On the front of the caliper, the c-clamp will be in the hole in the caliper, bearing on the outer pad, and in the back of the caliper, the c-clamp will be bearing against the brake hose fitting bolt. Right out of the factory shop manual.
Injuneer is offline
Old 05-26-2012, 11:55 AM
97z28k&N's Avatar
Well the bottom "bolt" did end up being a pin! Thanks guys, I now have excellent rear and front brakes!
97z28k&N is offline
Old 05-26-2012, 12:05 PM
jloshotz's Avatar
Great to hear when things work out well, enjoy!
jloshotz is offline
Old 06-09-2012, 06:11 PM
thewheelkid's Avatar
I suggest ALWAYS opening the bleeder valve on the caliper before pressing the piston back into the bore. By doing this you are A) not pushing contaminated fluid back past the ABS filter (on ABS systems), risking damage and B) it's eaiser to compress the piston when the bleeder is open because you won't be pushing fluid all the way up to the master cylinder. Once you have the new pads in place and the caliper in place, just leave the bleeder open to allow the system to gravity bleed until you have a light steady stream of dirty fluid seeping out.
thewheelkid is offline
Old 01-13-2013, 05:09 PM
cargotec's Avatar
to Thewheelkid, how would you have dirty brake fluid if it is a closed system
cargotec is offline
Old 01-14-2013, 10:05 AM
"Closed" is a relative term. A perfectly closed system would get no contaminants or moisture, but a brake system on a vehicle does not often live up to that expectation. Brake fluid is hygroscopic and any moisture inside can cause parts to rust and dirty the fluid. That is the most common cause. I don't think I have ever seen an aged brake system that was perfectly clean.
shoebox is offline
Old 01-15-2013, 03:12 PM
Ultra_Z's Avatar
maybe your bolt is frozen/seized?
Ultra_Z is offline
F'n1996Z28SS
08-23-2023 11:19 PM
Jazsun
12-29-2014 12:14 PM
FredM
12-18-2014 01:40 PM
Quick Reply: How to change rear brakes?
