Help with ABS code.
Help with ABS code.
My 97 Z28 is setting a front wheel sensor code.
I forget what code it is but it says that the sensor in the drivers side front wheel sensor is seeing the wheel spin more they the others.
Does this sound like the sensor in the wheel hub going bad or a problem in the hub itself?
I was thinking about replacing both hub's since that car has close to 150K miles on it and the sensor that's setting the code was a wheel hub I got from a salvage yard years ago and probably has maybe 130k on it.
Let me know what you think.
Thanks,
Thanks,
zajones
07-30-2015 02:18 PM
