Brake fluid
Old 05-02-2004, 11:03 PM
zoomjrl's Avatar
Brake fluid
I'm going to be installing the C5 Brake kit for my car soon. I figure I will prob have to bleed the brakes. Should I use synth brake fluid, or just replace it with what GM put in it? Anybody have any preferences on brake fluid?
zoomjrl is offline
Old 05-03-2004, 10:16 AM
Bone Daddy's Avatar
I use synthetic Mobil1 in 2 of my cars and can't honestly tell a difference v/s dot4 or even dot5 fluid. Either one would be fine.
Bone Daddy is offline
Old 05-04-2004, 07:44 PM
CamaroBoy96Z28's Avatar
I used the Valvoline brake fluid. Works fine.
CamaroBoy96Z28 is offline
Old 05-04-2004, 08:22 PM
Super Moderator
95 Z/28 LT1's Avatar
The best bang for the buck brake fluid I've found is the Ford stuff. It has a high boiling point for the price.
95 Z/28 LT1 is offline
Old 05-04-2004, 11:38 PM
Black_Z28's Avatar
Is that the brake fluid that is blue??
Black_Z28 is offline
Old 05-05-2004, 09:22 AM
Super Moderator
Nope, it looks just like most other brake fluids I've seen.
Old 05-05-2004, 10:28 AM
Black_Z28's Avatar
Hmmm, I wonder which brake fluid is blue. I've heard that's some of the best stuff you can get. From what I remember it had a 700 degree dry boiling point. I'll have to do some research.
Old 05-05-2004, 10:55 AM
LPEdave's Avatar
ATE Super Blue is blue, and they also make a "gold" fluid. The idea being that you can alternate between flushes to know you've completely flushed one out.
Keep in mind that as you go to the better fluids, they require changing more often. For the ATE/Motul type fluids, a flush once a year is typically recommended. So unless you're racing the car, you might consider sticking with a more streetable fluid.
Dave
LPEdave is offline
Old 05-05-2004, 12:10 PM
Black_Z28's Avatar
Dave
That's the stuff that I'm talking about. I remember a few guys talking about it at a car club meeting a while back. I kind of thought the color change would be a good idea. As you stated, you'd know that you've gotten all of the old fluid out once the new color started to come out.
Old 05-05-2004, 05:38 PM
mitchntx's Avatar
Late model F-Body brake system seals are not synthetic or DOT5 compatible. It will eventually eat the seals up.
A local police officer misunderstood and put DOT 5 in his Camaro, not DOT 5.1 It was ugly ...
Valvoline SynPower is a great street fluid. I have Castrol SRF in my car, though.
mitchntx is offline
Old 07-27-2004, 01:28 AM
tomatocity's Avatar
Re: Brake fluid
I don't understand. What is the correct brake fluid to use for F-Body's? I have a 1995 Z28 and would like to flush the brake system. I do not plan on racing or consistent high speed braking. Thanks in advance.
tomatocity is offline
Old 07-27-2004, 10:10 AM
LPEdave's Avatar
Re: Brake fluid
Mitch meant "silicone" brake fluid, not "synthetic" above. Your f-body cannot take silicone brake fluid, which is DOT 5. You can use any DOT 3, DOT 4, or DOT 5.1 (don't ask me why the numbering is like that) fluid, those are not silicone. Since you're not racing, I'd get one of the more "normal" fluids like Valvoline recommended above.
Dave
LPEdave is offline
Old 07-27-2004, 11:20 AM
LT4Firehawk's Avatar
Re: Brake fluid
Here's a great comparison article on the different fluids:
http://www.swedishbricks.net/700900F...Comparison.htm
For regular street use, the Valvoline Synpower is probably the best, and this is what I use for street and roadcourse use with no problems. Although, I do bleed a lot more often than would be nescessarry just for street use.
LT4Firehawk is offline
Old 07-27-2004, 02:59 PM
tomatocity's Avatar
Re: Brake fluid
Dave
Thanks for clarifying the differences. I plan of completing this before I leave for Hot August Nights on Sunday.
Old 07-27-2004, 03:03 PM
LPEdave's Avatar
Re: Brake fluid
The outdoor temperature at HAN is likely to be higher than most of those fluids' boiling points....
Have fun,
Dave
LPEdave is offline
Quick Reply: Brake fluid
