Need Advice on Steering Column Play
Old 06-01-2005, 05:01 PM
md66948's Avatar
I have an 89 IROC Z28. The steering column is developing lateral play. Movement is on the tilting part of the column. Has anyone ever had a problem like this? Suggestions on a fix will Greatly Be Appreciated!
Thank You!
Dane R. Marley
Wynnewood, PA
610-896-0217 - home
610-299-6360 - cell with voice mail
md66948 is offline
Old 06-02-2005, 09:38 AM
Compstall's Avatar
Re: Need Advice on Steering Column Play
You will need to partially disassemble the steering column (i.e. remove the steering wheel, etc.) and find the bolts inside there. Chances are they're loose.
Compstall is offline
Old 06-02-2005, 01:56 PM
RE AND CHERYL's Avatar
Either the bolts in the colum worked loose or the tilt column pins are worn. Both are comnon.
RE AND CHERYL is offline
14
08-11-2015 12:03 PM
GT what?
07-14-2015 10:17 PM
240ssLs3
07-13-2015 05:06 PM
whitehooptie
07-12-2015 06:10 PM
colts0455
07-07-2015 07:19 PM
Quick Reply: Need Advice on Steering Column Play
