95 TA rearend -> 99 TA? Worth it? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 07-23-2014, 06:38 PM   #1
Question 95 TA rearend -> 99 TA? Worth it?
Hey guys.
I recently picked up a 99 Trans Am. I'm pulling a few things off it and putting them on my 95 before I sell the 95. The 99 has the GU6 2.73 gears (auto). I'm going to be ordering a manual trans from Hawks, but would like better gears. The 95 has 3.42. Is it worth swapping the rears? I know I'll need to do something with the axles as the brakes aren't a direct swap. Anything else that might cause an issue? Or should I just order gears and have a local shop install them?
Thanks!
raxxus is offline   Reply With Quote
Old 07-23-2014, 10:19 PM   #2
Super Moderator
Re: 95 TA rearend -> 99 TA? Worth it?
Minor point, but 2.73's are GU2 and 3.42's are GU6.
Are both cars either ABS (only) or both ABS+traction control? They have to be the same to continue the operation of the ABS and/or TCS.
The e-brake mechanism and cable are different. I don't think the axles are an issue. The brakes mount to backing plates that attach to the ends of the axle housing.
Injuneer is offline   Reply With Quote
Old 07-23-2014, 11:10 PM   #3
Ack, good catch. It's GU2 on the 99 TA Auto. Neither have Traction Control but both have ABS.
So I'll need to switch the backing plates then?
Old 07-24-2014, 09:05 AM   #4
Super Moderator
Take a look at both of the brake setups and compare.
Old 07-24-2014, 09:14 AM   #5
Just a few things to think about. The 95 has a clutch type posi and the 99 is a Torsen posi. I put a 99 rear in my 94 and I couldn't tell any difference between them. If the 95 is a T56 the 2.73 rear isn't going to work very well. Both cars will need to have the PCMs programed for the gear change.
If you decide to swap them I would just swap the rear housing and keep everything else with the original cars. The axle shafts are slightly different lengths between the 95 and 99. I think this is to keep the calipers centered on the rotors with the different rear brakes. Everything about the two brake types is different so you'll need to swap it all. The easiest way would be to unhook the brake line at the body and swap everything with both rears out of the cars.
rngilliland is offline   Reply With Quote
Old 07-24-2014, 12:16 PM   #6
The more I dig, the more I realize it'd just be easier to find a local ls1 rear end with 3.42 gears for the 99 and leave the 95 as is. They are in the range of 200-300 around here, with 30 day warranties.
Thanks anyways gentlemen.
Reply
Thread Thread Starter Forum Replies Last Post
95 Z28 Worth blaze309 General 1967-2002 F-Body Tech 2 09-08-2015 06:27 PM
94 z28 48mm vs 52mm tb &air foil & tb bypass &maf colts0455 LT1 Based Engine Tech 18 09-02-2015 01:41 PM
How much is this 1969 Camaro Yenko Worth? Video mark0006 General 1967-2002 F-Body Tech 1 08-29-2015 10:45 AM
Trickflow/Edlebrock LT1 heads whitehooptie LT1 Based Engine Tech 2 08-17-2015 09:35 AM
Professionally Bulit Z28 with 402!!!!! mrwz28 Cars For Sale 0 07-08-2015 10:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
