CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   Suspension, Chassis, and Brakes (http://www.camaroz28.com/forums/suspension-chassis-brakes-47/)
-   -   1993 camaro z28 suspension (http://www.camaroz28.com/forums/suspension-chassis-brakes-47/1993-camaro-z28-suspension-880029/)
anmar A 07-07-2014 11:56 AM
so i just bought and installed the SLP suspension kit (Bilstein shocks and eibach lowering springs), but after the installation my ride became very firm and rough, like i would feel every bump on the road. my ABS inop sign just came on. i was wondering if something is wrong with the installation. is this kit any good.
Fatdog2 07-14-2014 11:15 PM
Re: 1993 camaro z28 suspension
Might check your third brake light and if it's burned out,that should fix this.The abs and the brakes are on the same wiring diagram.Hope this helps.:)
ACE1252 07-14-2014 11:24 PM
Depending on the rates of the springs and the type shocks, the ride can be very rough.
I put some aggressive rear shocks on my Z28 and dang if it didn't feel like the axle was bolted straight to the frame. I was "shocked"(pardon the pun) that the ride was so hard from just a shock change. I went back to an "FE2" option style shock. much easier on my backside.
Injuneer 07-15-2014 04:52 PM
Ditto.... Eibach Pro-Kit springs, and the back of the car chopped like a slammed S-10 pickup riding directly on the axle. Nothing I did with the QA1 single-adjustable shocks would help. Ditched the Pro-Kit. Actually rode better with the Eibach Drag Launch springs, but they sit a bit higher than stock.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
