South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Complete T56 Trans swap
Old 03-15-2012, 06:01 PM
1957camaro's Avatar
Guys,
same as Mightymouse, as the HP goes up, the less the consistency with a stick...I'm going to a powerglide trans
I have a T56 Trans with 0 zero problems, Hurst shifter & boot.
Two Spec clutchs, one 800 hp multi puck disc, and one 1000hp (solid iron disc) with "zero bal" Spec flywheel.
Mcleod Blowproof bellhousing
New GM clutch hyd's slave & master.
4th gen T56 crossmember...
Make me an offer.
1957camaro is offline
Old 03-29-2012, 08:22 PM
mightymouse383's Avatar
Re: Complete T56 Trans swap
Lol, yes Phil I see u are finally going with an auto, I am in the process of building my trans and then I will hook up the nitrous kit. good luck with the sale.
mightymouse383 is offline
Old 04-02-2012, 05:27 PM
1957camaro's Avatar
Angry Re: Complete T56 Trans swap
Yea,
I have two "Lookers" for the tranny and set up, one in Orlando, one in Lake City...
The electronics is here, just have to set up mounting plates.
(Pro Cube II, MSD LS Two step, MSD RPM shift driver)
I made a "Bad call" for a crossmember (Wolfe Craft) still hasn't shipped, nor built... (3 week wait)
Do you have a 4L60e crossmember?
(I can weld 3" plate to make it work for the PG)
How's your build going?
Old 04-02-2012, 09:11 PM
Its going good, I am building the tranny as we speak, waiting on parts from summit. I went with the BMR swap crossmember for a TH350, cost about $250 from summit. Shipped in about 3 days
I picked up a ART CARR 3800 stall, should work real good with my setup. Once the trans is all set up I will then hook up the nitrous.
Old 04-06-2012, 07:24 PM
1957camaro's Avatar
Sold...
Thanks for looking!
ch3vyb1gbl0ck
Classic Engine Tech
10-23-2023 08:07 PM
alphaauto
02-05-2015 05:25 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
cmdeshon
01-04-2015 11:15 AM
nballisru
12-14-2014 05:01 PM
Quick Reply: Complete T56 Trans swap
