South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
[Maryland] (4) camaro wheels 16 x 8 & tires 245 / 50 - 16
Old 11-08-2010, 06:27 PM
pboxfun's Avatar
Thumbs up (4) camaro wheels 16 x 8 & tires 245 / 50 - 16
This set of four (4) wheels and tires are from a 4th gen Camaro, but will fit any 4th gen F-body 93 94 95 96 97 98 99 00 01 02. May also fit other vehicles as well. The wheels are in great condition and the tires have less then 3,000 miles on them with lots of tread left. The wheels & tires are balanced and are ready to be bolted on the car. The wheels are 16 X 8 and bolt pattern is 5 x 4.75" or 5 x 120.65 mm. The tire size is 245-50/16
The tires are General Tire's Exclaim UHP (Ultra High Performance). The Exclaim UHP is General Tire's Ultra High Performance Summer tire that was developed for the drivers of sports cars. While meeting minimum tread design standards to be "M+S" branded, the Exclaim UHP is designed to provide high levels of traction, response and control in dry conditions, along with superior hydroplaning resistance in wet conditions. The Exclaim UHP uses a 2nd generation, ultra high performance silica compound molded into a directional tread design that features wide, solid shoulder tread blocks and a high-tech contour to combine responsive handling with dry traction. Its Double-V directional tread pattern enhances wet performance. Together, the tread compound and design help sweep water away from between the tire’s contact patch and the road to improve wet grip while reducing the possibility of hydroplaning. The tire’s internal structure includes twin steel belts reinforced by spirally wound jointless nylon on top of polyester body plies to combine responsive handling and cornering stability with high-speed durability.
I want to sell this as a set of 4 but I am willing to sell them in pairs if I have to. I need these gone ASAP!! If you have any questions or are interested please email me. I'm located in Southern Maryland.
SOLD
pboxfun is offline
Old 11-12-2010, 12:36 PM
pboxfun's Avatar
Re: (4) camaro wheels 16 x 8 & tires 245 / 50 - 16
Sold
pboxfun is offline
Steve69SS396
Track Kill Stories
15
08-10-2015 02:45 PM
Collector Car
01-05-2015 10:58 AM
hotrodyou1
12-20-2014 10:05 PM
globalprojeff
12-06-2014 04:18 PM
globalprojeff
Wheels and Tires
12-06-2014 04:09 PM
Quick Reply: [Maryland] (4) camaro wheels 16 x 8 & tires 245 / 50 - 16
