1957 Z28 Build
1957 Z28 Build
https://www.camaroz28.com/forums/members/1957camaro-79667-albums/
Here's the past 14 months build of the 57Z28
This car is going to be one bad rod ..Pics just don't do the car justice .And the motor!!Well lets just say its one nasty lt1 .Good work phil .HURRY HURRY !! HUH YOU SAY TURKEY ROD RUN !!GETER DONE!!!
Update on the 1957z28
Well,
The body is now kinda strait. Primer, sand, Primer, sand, etc...
I cut out the cowling so the sheet metal intake will fit, and cracked the windshield (DUH), so when the glassman showed up and removed the glass...
We found RUST...
So this past weekend I used / welded a roll of MIG wire fixing the area between the top of the windshield, and the T Tops.
The sheet metal Intake is still not finished, but I found some NOS Nozzels
The foggers that go under the injectors.
see attached pixs...
We found RUST...
Roll Cage complete
Update...
The 10 pt. cage is now complete.
All the joints were TIG welded, the plates were MIGed...
Pictures soon to be posted. (Paint needs to be done before surface rust...)
Thanks to "J Dog"!!!
1957z28 Update
The dash is complete, and the windshield was installed last night!
The base white paint, I'll spray this weekend!!!
Then the weeks of mid-coats of pearl, Ghost flames, etc...
The 2010 Turkey Rod Run, is "Just around the corner"
10-31-2016 11:09 AM
Moshbmx1
01-20-2015 03:27 PM
NewsBot
12-17-2014 02:50 PM
Bearmans
12-03-2014 05:28 AM
