View Full Version : LT1 Based Engine Tech
- wiring for dynaspark?!? (install help)
- 95 lt1 cadi motor ????? help!!!
- Would This Cam Be Good For Me??? Solid Roller
- i need #,s of a 97 main caps
- LT1 with old school distributor?
- Radiator Plug
- parts list
- Any improved rotors for Opti ?
- Anyone with an Autometer A/F ratio gauge
- jet fan switch
- Air Intake Help
- A.i.r?
- 94 lt1 ?'s
- What valve covers R U using? ???'s about using Lt4 valve covers, also need part #
- TB help
- EGR prob
- Squeaking/Jingle noise around alternator.
- Heads and cam
- Air/egr?
- dowel pin length
- help with some DTCs and stall
- Starting Problems
- LT1 rail covers for Fbodies, where?
- shimming valve springs for basic cam swap
- carburated lt1
- whats this called
- Delco Opti on E-Bay
- Stock Spring Replacement?
- Recommended Engine Builder/Machine Shops in Washington???
- March Coupon Promotion
- Where to get SBC heads converted??
- reverse cooling?
- Opti Harness Question
- help???
- 4L60Help
- Hotcam at 173,000 miles?
- Backfiring
- 1995 LT1 Problems really WIERD!
- Hotcam or wait.
- main cap question
- Water in oil??
- Car still running like crap
- Ideal compression ratio?
- 94 T/a LT1 running like crap
- LT1 Valve cover options?
- what the hell is a dizzy
- Summit ignition
- Car Stalls?
- timing chain
- Diamond Pistons...Where to get 'em?
- Part # for LT4 off road intake gaskets
- Oil pressure sensor angle fitting
- lt4 knock module,
- hey I have a simple quick question about the LT1
- 1st time at the track : need advice
- stock stall with cam
- Lt4 Hot Cam Kit
- Need to solve my Cooling fan problem
- Need help with emission compliant 355 combination
- Installing a 96 camaro LT1 in a 305 buick roadmaster
- Price for 02 sensors?
- stock timing chain install
- Spark Plugs
- idle problem/low end miss
- what do you think of this engine?
- Which cam bearings?
- Car won't fire...
- Complete LT1 gasket set
- Why is my oil pressure this low!?!?
- Air Induction
- engine knocks at shift point
- Which Roller Rockers?
- Pass. side PaceSetter header hits motor mount??
- Bad ticking and rockers have play?
- opti question
- 93-94 Steam Pipe
- Which PCMs are interchangable???
- What goes in this hole???
- Will a Gen I block work with lt1
- Does the 93 LTI Camaro's....
- 94 Z Opti questions
- Opinions on comp cams 986 springs please!!
- Oil pump priming question...
- Need help NOW (Car won't stay running)
- AIR system
- quick hotcam question
- hotcam on high mile LT1?
- Underdrive Pulleys for Lt1
- tach HELP PLZZ
- High Idle Problem with 58mm BKK... SOLVED
- Need some help wiring o2 sensors
- Gas smell/evap questions.
- 160 tooth Flexplate?
- pushrods for upper 6k rpm and solid cam
- Any1 buy just the MSD cap/rotor?
- anyone have longtubes/nocats/loudmouth?
- Lt1 Water Pump
- in process of changing plugs
- Car smells like gas
- Tuning Question
- 95 Z28 problems...
- timing cover need help!!!
- dtc 18
- 95' Z28 with gas mileage problems
- Anybody running XFI cams w/ less than 113 LCA?
- I was getting ready to hate on Holley fuel pumps...
- Blue Fel-Pro oil pan gasket help
- cc306 normal or do i have a problem?
- Custom BRE cam
- Help installing MSD
- not starting up
- 4 bolt mains and big crank... can u pull oil pan?
- new motor, wont run.....
- 500hp combo ?
- Best Plug for High-Compression LT Engine
- Blown upper radiator hose
- ASR or Cruise Control On Drivers Valve Cover?
- bent pushrod/broken valvespring..need help?
- SLP CAI replacement filters
- Scorpion Rocker Amrs
- at wot car vabrates bad
- GM Performance Parts Lt1/Lt4 crates
- Car does not idle well and backfires when getting of gas
- LT-1 Valve covers with roller rockers?
- cams and emissions
- going cai
- engine harness wire unplugged, what is it?
- dyno numbers hot off the press
- Externally Balanced Flywheel?
- 52mm tb or EWP on a hotcam car?
- Why Do We Have A Sticky For New Ls1 Parts???
- rough idle/bad throttle response=>ecm changing always open/closed loop!
- LTCC red and green LED's...
- new dyno numbers..problems follow
- Heating up on Highway
- Seafoam question
- Callies Crankshaft Identification HELP please.
- Need help with a vacuum hookup (97)
- What oil pressure is normal for an LT1?
- What cam can I get on a 110 lsa that'll have a good powerband up to 6000rpm?
- Timing cover
- how to check my cam grind number
- lt1 short on oil
- Pacesetter emissions fittings
- lifter question???
- BBK Throttle body
- Quick question!
- New to the forum, 1994 firebird LT1 knocks after start
- Cam bearings
- Anyone know all the specs on a GM847 cam?
- computer swap
- Harland Sharp Roller Rockers?
- How to remove PS reservoir
- Low Vaccum
- Horsepower guestamit
- Eliminating the steam pipe on LT1s
- le1 cam w/le2 heads
- which RR is this, pic inside
- XE 230/236 cam
- Warped Intake Valve??
- WOT problem
- which locks and shims/locaters with these springs and retainers?
- BBK 58 on my auto lt1
- Oil pump pickup differences
- Which piston rings?
- oil pump questions
- Engine Issue
- Difference in LT1 Throttle Bodies
- Anyone ever used Stainless exhaust flex-joints?
- Motor mount torque specs...
- starting off
- wiring harness
- Need TB Torque Specs
- Holy exploding lifters
- I'll help keep the lt1 alive
- Spark Plug Wires
- Codes!!
- looking for best hp gain add ons
- SA or NSA rockers??
- anybody ever get a comp cam that was degreed wrong?
- Splayed 2-bolt
- cc306 with Crane kit 10308-1
- full roller or roller tip..... oppinions?
- high rpm preventative maintenance
- Can the LT1 make good power?
- Who's gonna be the Edelbrock intake Guinea pig?
- Headgasket...
- Whats the stock piston volume?
- Will these parts work well together?
- Recommendation on 58mm TB that won't have IAC whistle/sucking sound issue?
- Rocker Arm Issue! Picture
- How are the battery cables routed?
- 396 Hp
- Need Cam Advice
- think i can I use these rockers on my lt1 cam swap?
- OP Drive Shaft through top??
- fix for leaking opti drive seal...look here
- Opti Harness
- Gain from power steering removal?
- gold race series rockers
- Cam Swap Gaskets
- what bearings?
- Head stud part number??
- Whats the risk
- Retainers and Locks for Beehive Springs
- Well I have some time on my hands so I thought I would..
- LT1 Plate **Group Purchase**
- Mahle Powerpak longevity
- Opti keeps getting wet.
- runing rich?
- intake differences
- differences between intake elbows?
- i need a p/steer delete pulley...
- obd 1 scanner
- would any of you buy these?
- Need help finding the correct valve lock
- Alternator question
- MSD Opti worth the money??
- spun bearings, why?
- 93 TA radiator cover on a 93 camaro? LT1
- LE3 pictures
- head only bolt on lt1
- How much HP will this add??
- Replacing Valvesprings
- 1.8 RR's on a stock LT1.
- GMPP 1.6rr with cc306
- LT4 Starter
- Picking up 1992 LT-1 Vette-opinioins wanted re: things to do
- physical difference between SA and NSA rockers
- fans won't turn on..
- Stock lifters in big cam setups
- which valve spring for .650 lift?
- Will this timing chain work for me?
- Hard starting after sitting overnight
- Crane Lifter Adjustment (high-performance HD rollers)
- cc306 = 1.6 what lift?
- stock shortblock max safe RPM
- Static Compression Ratio Quiz
- quick video
- 230/236 duration and .570ish lift streetable and reliable?
- Might get a 95 Z..
- Milling the intake
- Is this the right size crank/hub bolt?
- Cylinder head bolt re-torque...
- New Opti, same problems
- egr port cleaning
- Broken Bolt in Leaky Fuel Rail
- supprised i got a 4 bolt main block
- lt1 timing chain
- Time for a cam....I don't know jack about cams
