View Full Version : LT1 Based Engine Tech
- canton valve covers
- Cheapest place to buy GM opti?
- This makes a good weekend go bad!!!!
- 918 Failure? Please post date of purchase and Batch Numbers
- Msd pro billet option with Delteq
- ported header gaskets that don't blow out?
- lacking power at WOT
- I think my car is running pretty good
- 224/230 110 LSA part number?
- need new crank hub +underdrive pulley = ATI 917271?
- 36# injectors
- 383 question
- Spark Plug Boot Insulators.
- Hot Cam Kit With Out A Tune!!
- Need some help with this one LT1 oil block off ball?
- ASR shut car off?
- bosch plugs ?
- Car is done....FINALLY!
- 450rwhp?
- Stronger header gaskets?
- Cooling Fans Ground?
- 95 LT1 engine hesitation
- 383 short block
- Dealership has a 93 Lt1 camaro for $7,985? Good price?
- Lt1 Oil block off ball can anyone help?
- Sent this email to Comp Cams
- Good Trade? A stock Maf for a Aftermarket maf?
- Intake manifold to head port sealing question?
- Timing set with 306
- what injectors are these?
- ? about roller rockers
- Oil coolers
- Eagle 383 balance issues
- Difference in 94 and 95 lt1.
- Which oil pump?
- Where to buy a scanner for my 95z
- H/C vs. Cam only... thoughts?
- Water leak near opti
- stumbling when on brakes
- Obscure part missing Oil block off ball
- One pushrod flows a lot more oil than the others. Problem?
- 94 caprice crank and hub + 97 camaro balancer?
- why are eagle SIR rods only rated to 6K RPM?
- Limits of stock LT1 bottom end?
- CPS crank to "pre" CPS crank - can I just move the reluctor ring?
- Coil Pack
- Intermitent problem with injectors not firing.
- LT 1 Crank question
- Anyone else have charging issues with EWP?
- Best plug wires for AS&M headers?
- Best way to clean opti?
- Where to buy LT4 hot cam kit
- Moroso filter replacement
- Header help
- Ses To Pcm Wire
- Want to crank without fuel or spark
- oil change . . .
- Opti got hit with coolant...any way to save it?
- Stripped out threads on flywheel housing
- 52mmtb update
- Major Problem, please help! LT1 Major Misfire and Running Hot and Very Rich!
- Colorado Altitude and Compression
- Platinum plugs
- Z28 Mechanic
- Which spark plug is colder???
- Need some taller valve covers who makes em?
- What are Comp Pro Mags supposed to sound like?
- Lifters and pushrod question
- Can someone help me out with a measurement?
- Backfire new 396 NEED HELP ASAP!!!!
- Open hose? whats it to?
- Starter bolt size 94 LT1...
- Lean condition
- LT1 swap question, knock sensors
- Next mods on 383...
- good tune place on L.I??
- 1995 z dont run.
- Does switching from OEM lifters to Morels require different PR length?
- relocating alternator
- Lost power on the dyno...what could cause this?
- Push rod length?
- Looks like there is a problem with the 918's after all
- Max lift/spring pressure with stock LT1 or LT4 timing chain?
- Using a valve spring micrometer?
- New exhaust vid
- horse power or some other things
- Anybody running a converted dual plane?
- 396 stroker anyone??
- Question for those of you with the SLP CAI.
- overhaul question
- Turned engine removing balancer bolts, will timing be off installing opti?
- what next?
- MSD Opti Owners...
- What is the C.A.R.S. in our PCM??
- Bought A cam based theory any realworld exp.
- summit plug wires
- What times can I expect from 94Z LT1 A4?
- can i keep the 93 tranny when switching to a 94 pcm?
- Weird idle and check engine light
- opti harness symptoms
- lose data communications with PCM when running but have it when off
- MALF 33 only in Stop N' Go traffic
- Car stumbles and backfires
- help me please!
- cam iinstall
- balanced crank
- knowing TDC on cylinder one
- just wanted y'all to know, comp cams and their valvetrain components
- Clearance between Oil Pan and Steering Rack....strokers inside please...
- shop says water pump / timing cover is clanking when engine turns off, help!
- aldl connection and miss!!!!!
- How much am I looking at?
- May be Joining the LT1 owners group - Advice please
- cam selection w/ a stroker
- ati balancer & bolt comming loose.
- Stock lifter limit
- Need power steering high pressure line part #
- Moving to H/C, am I forgetting anything?
- lifter ?
- How do i get ahold of Bret.
- Knocking-ish sound
- lifter load
- REBUILD KIT + CAM KIT!!!! I need your opinion
- ??? 383 or 396
- RE: LT 1 sounds like metal on metal
- Optispark gouging
- LT1 Missing..HELP!
- Good mods on a worn motor?
- Need help on heads, intake and cam combo
- Head coolant passage question - important
- Emissions test failed, any idea what's wrong?
- 383 le3.2 cam , le3 heads timing comparo
- P0141
- Surging throttle-Not under load
- cammed Lt1 stalls when on brakes. Please help!
- Motor Swap
- Bolt size for pulley above AC Condensor.
- MAF/O2 Fuel control questions
- TEA Trick Flow LT-1 LT-4 Dyno Numbers ...
- code P0118
- throttle help
- Need a GOOD headgasket for 200 shot, and need bore size.
- LT1 died this morning, need diagnostic help
- where to start?
- Pac 1220s or crane 99893
- Moto is almost together!
- MANELY GUIDEPLATES on LT1 ?????
- Car dies
- Canton oil pan and pan rails?
- valve problem
- Crank hub install
- Help! Good LT1 Shops in NJ?
- hesitation, stalling, rough idle, intake backfire?
- Alternator question
- Where to find pigtails?
- DTC P1626 Theft Deterrent System... need help to defeat it.
- LE1 cam on stock heads?
- Oil filter adapter bypass valve
- fuel pressure
- Closed Loop Stutter
- Oil pressure and fuel pressure questions
- 11.41@118.49 Na Lt1
- Brodix LTX heads
- Small oil leak after new opti and ewp install...
- Oil temp gauge install
- Dirty/Plugged Injector?
- LE2 Build completed... (will not start help needed)
- I need a new engine, help me choose what to get, 1994 Firebird Formula
- Pushrods Too Short Now
- help rebuilding
- PCM Ground Burned Up
- How bent is bent?
- valve adjustment problem
- Oil Pump Mounting
- '94 Z-28 Water Pump
- Lt1 383 stroker questions
- power loss, help please
- need comp cam # on this cam
- Gen 1 and LT-1 What bolts are the same?
- MAF to THROTTLE BODY metal bellows,who makes them?
- to the 383 guys
- ~7 mpg= [edit]?!
- Jasper Performance Products
- Guess I got lucky (accel opti)
- guage questions
- Maf Was the problem.
- Hot Cam Set Idle
- Fans only on with a/c
- my 224/230 passed emissions!
- Better Motors (higher output) for the radiator fans?
- To those with HotCam experience!
- running rough...
- 95z28 Starts then dies. HELP!
- Fouling Plugs
- car sputters below 3000 rpm any comments?
- how much power?
- Car shook violently would barely go and died now won't start?
- 383 stroker help
- Need a good LT1 tuner in Oklahoma or Kansas
- Spark Plug Length Info Thread
- heads,cam
- adjusting rr's please help
- dash light on,but no code
- Steering shaft is rubbing only when turning right
- High mileage LT1
- Heads on ebay.. decent deal or not?
- Missing Bad! Losing my Mind - Help!!!!
- LT-1 rebuild in my future, help me decide...
- How to check ignition timing
- YEAH! Just got my motor mounts!
- What are these?
- installing a 847.. some last questions
- Throttle Body System
- fans not coming on
- bent valve question
- guage question
- Fan Turn On / Temp Sensor
- I NEED A CAAAAAAAM lol
- Stock bottomend+ ported heads=
- I can't find passenger side o2 wire (1-wire)
- Competition Thinks Ai Car Has 700 HP!
- Looks like my engine is about worn out...
- Code 16 Help
- Help Needed Choosing Rotating Assembly
- running rough
- Opti/Motor Swap
- LT 1 splayed main caps
- Trick Flow heads and Edelbrock LT4 intake
- Racetronix injector install ?
- Wideband readings vs datamaster
- Too many add ons - any electrical engineers?
- Edelbrock LT Performance
- Meziere WP Fuse Keeps blowing...
- will sbc rockers arms work on an lt1
- What size threads on intake bolt?
- speed den to maf
- starting to get frustrated with car
- Car has a miss and I'm stumped
- Does anyone know the part # for k/n
- Removing heads only
- Water temperature
- Parts Question
- 1995 LT1 proper cam pin length ????
- LT 1 sounds like metal aon metal
- A couple cylinders fire, then nothing...
- Car's running really hot
- LT1 FUEL RAIL COVERS do ya have some??
- what gap for ngk tr6
- Overheating Badly
- Engine Block Identification, Help Needed!!!
