View Full Version : LT1 Based Engine Tech
- 94 Z28 overheating
- Random Misfire
- High RPM miss...about to drive the car into the bay
- Quick SEAFOAM question
- First time out w/carbed LT1
- What kind of Guide Plates are you NSA guys running?
- 285hp in a 97LT1 Z28,at the tires or flywheel?
- Help for a friend's setup: LT1 into third gen firebird...
- Springs on stock motor
- waterpump question. urgent!
- IT RUNS AGAIN!!/ LT w/ 847
- HELP! Miss on #7 on new motor
- oil pump question
- i really need help guys,
- 10.52 NA Pass 95 396 LT1
- help on picking right main and rod bearings
- Running richer than Donald Trump!
- 93-94 MSD opti owners in here!
- oil light comin on
- optispark question!!
- Iron LT1 Heads
- What kind of LT1 stock Alm. Heads do I have?
- New toys for my car! Cam, headers, 1.6rr's, etc...
- Contact info for Morel
- Tell me what I need
- Will the LT1 intake manifold fit on an early small block chevy engine?
- 96Z-stalls,hard to restart,p0430,p1441
- search didn't answer this - where do opti hoses go with new elbow?
- opti help... yea
- Best place to buy a compstar rotating assembly
- Remove Air valve off headers??
- Madz28 tune...
- NSA 1.6 RR's (questions)
- Bottom End Build: H/C with N20
- Why don't head porters use LT4 valves on their heads?
- Niehoff IAC valve
- fuel leaking down into inejoctors?
- Big Boy Fuel System ???????????????????'s
- What wires for LTCC and AS&M Mids
- Replacing Heater Hoses
- Changing my oil today...
- Code 1441
- Has happened a few times....where when i start the car up the RPM's guage doesnt read
- putting together shopping list for LE package
- Building an LT1, can I use a Vortec 350 shortblock?
- Heads/Cam/Opti/Water Pump install...
- Low Coolant light won't go off
- P1351 ICM CirHighVoltage (seems to be unsolvable) **MERGED THREADS**
- need some quick help with my 93
- Found my answer to "but how do you fix it"
- Are these roller rockers any good?
- Isnt 14.10 a little slow?
- a-i intake porting
- DIY head porting?
- LT1 problems
- Too much oil
- intake manifold leak?
- OK what year is my engine?
- Strange Ignition problem
- How long to replace spark plugs and wires?
- 1.6 RR question
- More engine problems w/ video
- LT4 hotcam kit installed, and problems after
- Intake manifold and distribution
- is a pcmforless tune good enough these mods?
- Best Valves for LT1 Heads?
- Autometer NV Series FP Guage
- Pushrod question
- running hot?
- valve spring seat cutting?
- Went back to the track yesterday...
- BAD coolant leak...
- my next round of mods..
- oval port headers
- spun bearing? video
- does this sound like a clogged fuel filter? (random start/idle problem)
- Are hellfire rings necessary with this setup?
- Installed 1.6 1418 COMP rockers
- car runs rough when warm
- Squeek in Pulleys
- Those with AS&M TBs...inside please
- What is this ticking noise?! (video)
- help selecting cam for ported stock heads
- radiator rust help
- No Idle, Runs ROUGH & smoke...
- accel dfi gen vi
- First start on new motor!!!
- assembly questions
- best move
- Timing Cover Leak+Cost??
- Broken bolt in Timing cover/front of block Please Help
- heater hose location
- Car runs rough when cold
- Moving PCM into car
- Tranny Shake on Highway @ Low RPM?
- "Service Engine Soon", reset and unhook battery?
- Bleeding the Coolant System
- finally made it to the track with new stuff CC503
- Stripped spark plug thread repair?
- Need help ASAP
- Cam help!?
- OTVC plug wire boots - any tips?
- Engine shake, clutch?
- Waterpump is done, car getting hot real quick still
- Average Machine Shop costs for the following work???
- HELP!! is this a LT1 thermostat or not????
- gearing & MPH question
- Please help with 97 SS Stuttering
- Optispark firiing order diagram
- P0103- Code
- New stainless LT1 longtube headers coming to the market: your opinions needed
- MSD Universal / Cut-to-fit Wires
- Ls1 airlid conversion
- found idle/dying problem
- Entropy aluminum radiators?????
- Now on hour 8 of water pump install
- How to replace coil wire?
- Ordering an LE2 package
- AC compressor / same as
- Where are the drain plugs on the block?
- Preload on GMPP Lifters
- Pro Mag's, Trunion problem ... ????
- ac code delete, will it still work?
- longtubes hang low
- 95 motor build up
- But how do you fix it?
- 3 questions
- High 11s with the converter swap?
- I feel stupid for even asking this but...
- sensor?
- Fuel pump died - should I get the Racetronix kit?
- ARP main studs question...
- msd wire accessories, where to get?
- Bad Oil Leak
- Limits of stock crank???
- oil pressure check with mech gauge question..
- rough idle gas smell
- Opinions on the LT4 hot cam kit
- What do you need to get into the 12's
- Where these lines go to...
- MSD Opti problem?
- Deleting Traction Control Questions???
- Help: MSD 6A & A/C Delete
- Another high rpm stumble/miss question (did search)
- URGENT will 95 a4 work in 97
- Last minute help before I put it together!
- 97 throttle cable pics
- Overheating/Cooling Fans Update
- Volant cai please help
- question on setup.
- Took Car to the track and was running bad...
- Low ET's and Trap speeds from cc503
- Replacing Intake gaskets on NEW engine
- overheating AFTER shutoff
- CAI or Ram Air?
- who has a cam and e check
- CSR water pump question
- electric waterpump relay hookup
- cam install now car won't rev w/video!!
- help.. overheating bad
- Running rough
- Can The Opti Be Installed Wrong?
- LS6/Z06 MAF on LT1
- LT1 Steel CAMSHAFT OIL PUMP DRIVE!!!! No more plastic!!!
- Time for new WP??
- Any good shop for LTX base f-body near...
- looking for a few sound clips
- Car cuts out at part/half throttle and almost instantly happens at WOT.
- Leaky injector confusion. Proper start up procedure verification needed.
- Knock sensor install torque spec...
- Where do these alternator wires go?
- TPS Issue..
- Trouble codes EGR or tune it out, tune is needed..
- Lt4 Hotcam
- Wierd noise, almost like a knocking (video)
- Lt1 Carbed Conversion What Cam?????
- Lsa
- LT1 high RPM popping sound???
- 226/234:need valve events/overlap @.050"
- LT1 tune install question
- Cam?
- ac deleting question
- Are we selling the stock LT1 head too short?
- Part throttle accelleration problem.
- Do your rockers make any noise?
- New Times with 388ci, motor times!
- knocking or clanging noise?
- Oil cooler?
- Does this mean my fuel pump is bad?
- rod bolts hitting windage tray
- cam swap, something weird
- MSD Optispark
- Good/Bad Consequences to these mods...
- Afr Lt4
- What camshaft kit?
- Installing Manifold Vacuum Gauge
- no injector pulse, new msd opti
- Back in the game. 9.56 @ 143.68
- ICM grease?
- Check engine light
- NGK TR55 Plugs??
- Water pump blues
- ARP 134-3701 torque specs...
- check gauges light flickers on and off...
- Need some help....
- Recurring codes
- Cooling Fan relay
- Timing/Cam Dowel Position
- SummitRacing throttle body thumbs up
- so i just picked up my first camaro
- What do you guys think of my times?
- Spending 300-500ish on new toys
- LT4 heads
- About pcmforless
- Would hedman tork-step headers fit?
- premature spark plug failure
- Where to find OBD 1 Values on 94 LT1
- cam install questions
- burnt wires
- 11 mph hwy?
- changed mass air flow,still won't run
- random misfire
- Carbed Lt1 Conversion ???????'s
- Ported heads with cc503???
- arcing wire question
- not running right!!!!
- RPM range for cams
- New personal best today for my bolt-on LT1...
- BeCool Thermostat
- No check engine light after unplugging IAT sensor.
- Solid Roller Lifter part numbers, please.
- header problem
- Weekend cam install LT1
- Ported Intake
- Question about GM waterpump tubes
- New JEGS Non-Vented Optispark - now wont start - PICS INSIDE
- lt1
- Here's some good reading.
- Can Alternator Cause Performance Issues?
- [for sale content deleted]
- Self Align Rockers with Beehive springs?
- rough idle after warm, SES light on when cold!???!?!
- well......
- Just curious.....anyone ever blown up their Golen shortblock
- ? What is the recommended bearing clearance for 355 & 7k rpm
- Rocker Adjustment
- Anyone else breaking Comp polylocks?
- Radiator Relocation
- help with fuel pump? maybe something else
- Gasket package and sealant for H/C swap
