View Full Version : LT1 Based Engine Tech
- Hemi Lt1
- Starter problems(new questions)
- Gasket kit...anybody know what these are for?
- oil?
- Have a definitive Felpro part# for LT1 Valve guide seals?
- Need Help Loud Noise!!!
- So something is wrong with either my speedo or M6 has odd gear set ???
- can you get cm612s anymore?
- Lt1 Headbolt torque question
- More info on the ignition problem
- 383 Hard start and hesitating
- oil pressure question
- Anyone know this connector?
- Won't start
- OBD2 not connecting to scanner
- Low coolant light, worried
- Oil pan gasket
- help with rebuild....
- Bad weekend working on the car...
- Backfiring
- L99/LT1 intake manifold Question?
- Single Plane EFI
- Le Cams
- Am I down on power?
- Drilling the IAC valve on a new 383 T/B Need Help
- fuel pressure
- Engine choked, wouldn't start, then started again
- lt1 cam cc305
- Tunning for a new Converter?
- Modded LT1 vs drivability
- 350->327?
- lt4 valve cover clearance??
- Upgraded backlights and.......
- Please Help!!!
- Blown water pump?
- Need assistance reinstalling heads
- rookie here........bad misfire
- Single-cat to dual-cat
- Weird cooling system problem, need some help (lots of pics)
- raced a cammed 06 stang last night
- which cam
- intake gasket
- Lt1 overheating.(Water dumping out overflow tank)
- Will LS1 style cai fit under stock 93-97 hood?
- Can I run stock rockers with a CC 305 cam?
- Best injector cleaning service...?
- Pluggin dist. hole in a victor intake
- Low voltage scan?? Need help
- Datalog: Bad O2 sensor or Misfire?
- I can't scan
- New Opti & No Start - Need Help!
- Stock Flexplate Weight?
- fouls plugs and misfires
- VIDEO -WOT 1-3, BRE Cam Only, Bolt On Car
- re-use lifters from blown motor?
- What actually is a "collapsed lifter"?
- Through the top?
- Engine balance
- how to remove wired connections from underhood relay box
- finally got her fired up vid
- Ok, i need some help....
- Better buy 97 lt-1 50k 99 ls-1 100k same price
- Lt4 383 issues!?!
- canton oil pan rail question
- Fans running all the time, AC stopped working?
- New 383 performance issues
- shift light
- broken heater hose...need some help
- Air Intake
- Whats this wire, and these boxes/modules
- Grinding noise at startup
- found another leak, picture
- Semi-Cheap 383 Cam Selection Help
- is this oil leaking? pics inside
- Video/Soundclip of 388 Ci Stroker LT1
- .040 overbore possible
- I need some help, sputtering LT1 undering @ 1500 RPMS
- Are 217cc runners too big for a 355
- Felpro 1094 head gasket
- Will these fit right?
- lt1 knock sensor/ or icm
- Oil Leaking into Valve chambers
- Intake Studs
- I'm stumped - bog/missfire?
- New To Boards!!!
- Trouble light on 94 camaro
- pacesetter LT clearance with canton fabbed valve covers
- LE1 heads with cc503
- scan/real time software
- Times for my LE 383 setup - 1st try, what's my potential?
- 1.7 Scorpion RR valve cover ideas
- Idle problem
- BRE Cam, Stock Heads, Idle Video
- 96z-dealer stumped-stalls or won't start
- Valve Covers
- next mod
- Is the hot cam kit the best bang for the buck?
- How noisy are shaft mount rockers?
- Coolant blew out of resevoir?
- new engine smoking at oil filler
- does not idle up when booster hose is disconnected
- NEED HELP!!! valvetrain question
- trickflow heads
- Coil Pigtail Part Number
- for those who have had fan issues
- Oil leak, where's it comin' from?
- Digging through my archives.
- rocker arms
- RTV for water pump gasket...
- Chewed Wires
- Water logged...floating LT1
- FLow Numbers for 383 Heads?
- Tips on grinding a block for a 383?
- brake booster thingie?
- testing/cleaning fuel injectors...
- Has anyone tried the new Edelbrock heads and intake?
- 94 camaro z28 runs hot when stopped.
- Starts then stalls
- Car fixed w/video...
- Hard time starting
- New Clanking sound ... wtf?! ---
- Oil Pan
- low rpm stumble
- help with TPS high voltage code please
- Bottom leaking oil!!!
- Fuel pump possibly?
- K-1100 solid roller valve springs. You use them?
- My 97 Z28
- ICM test...
- Replaced plug wires...problem persists
- Aftermarket Tach w/shift light in A4?
- Intake gasket.
- think my 95 can take a G35?
- fans wont work,checked everything!
- LT1 intake fit question
- abs inop light turned off now ses light is on?
- SCB 4th gen guys....
- what eng. temps are people seeing the best HP with?
- Valve covers & 1.6 roller rockers
- Using Total Seal - Quick Seat powder on new engine
- Comp CC 305 vs. Comp CC 306
- . 355 crate motor with cam and lt4 heads
- ALTERNATOR Clearance Problem
- pulling engine problems
- 3 wire coolant temp sensor
- electric water pump
- header gaskets (94 rebuild)
- Cammed 1994 z28
- timing chain questions
- intake exhaust gaskets
- No power to starter selonoid
- need help! idle too low!
- heads & cam installed
- LT4 timing set noise or worse???
- best price melling select?
- valve lash diagram
- intake
- map,vaccum, and running problems
- cat??
- water in ecm
- Vacuum on 383 engine
- Cam card needed for 63-224/236-114
- Will LT1 intake fit AFR 195 heads?
- sk speed
- runs wierd
- fan relay was replaced with jumper - why?
- Oil Leak ..
- Weird problem after opti install?
- Strange electrical failure
- Whats the highest compression ratio i can run on pump gas (93 octane)
- coolant temp sensor
- New 383 will not idle
- +1 For B.R.E. & PCMforless.
- oil ????
- Even More MSD Opti Problems
- lt1 heads
- what times should i expect?
- ID Intake Manifold
- quick data master question
- How do I test the opti feed signal to the pcm .
- starting problem
- URGENT, backfire with 383
- E.B Porting, heads are in
- Starting 383
- 97 z28 fuel cut off
- Going from synthetic oil back to reg
- Opti? Please help!!
- lifter problems Help ASAP
- Not running perfect any more
- Idle surging badly... story and log inside
- Re-calibrating the MAF...
- does the msd box really help any?
- Emissions delete, what can I remove?
- Caprice LT1
- please help! misfire/extreme rich condition
- Have leaking from valve cover after install
- blowing my fan fuse
- engine fan
- 1994 vacuum line
- Help 94 Lt1
- cleaning o2 sensors
- radiator fuild
- high RWHP cars
- Bad O2 Sensor? mV and BLM Graphs Included
- Knock Sensor / Block Drain Plug
- oil leak
- Ohh darnnit all....
- 1996 Reluctor Wheel GM Part #????
- Need help on timing chain and waterpump questions
- removing unused outputs on waterpump
- Nitrous Camshafts
- Almost done, Help me troubleshoot!
- header fitting question
- Ok, so let's make sure this is my fuel pump
- 7/16 rocker arm studs..which ones??
- Cold idle problem.
- experienced cam input please
- cc306 questions
- vacuum line
- Dyno tuning LT1 's?
- hooker headers problem
- Passenger side wires...
- plugs and whires
- lost of overheating problem
- Intake Manifold
- MSD Dist :w/ NOS Tune
- 3 sets of wires and still arching
- gradually running worse - why?
- While replacing the Optispark...
- Stock 96 Z28 SS....where to start?
- Any other possibilities for a missfire?
- !evap
- pacesetters ruin o2's
- LE head porting?
- 93 lt1 in 97 v6 help !
- help! VERY VERY loud scraping noise from engine bay
- Autolite Wires?
- put me in the right way..need some help
- getting closer, but can't go WOT
- blowing white smoke at idle intermittently
- rebuild time
- o2 sensor part numbers?
- ariaona speed and marine headers
- RPMs Rise Sitting in Traffic
- Need LE2 spark plug advice. Autolite Platinum tips hotter than regular 104's?
- Startup problem, is this my starter?
- best way to drain coolant without making a mess?
- Heads and intake...
- loss of performance with no obivious problems
- Heres my LT1 rebuild list, opinions?
