View Full Version : LT1 Based Engine Tech
- Using 96 Opti on a 95...
- Cloyes Double Roller Timing Set?
- How to tell if you have to much HP
- Please help me identify the problem
- Access to Rod/Main Bearings?
- Autometer A/F gauge install...
- Wires from o2 harness to PCM
- Bad idel on first start after cold night
- Tired of people talking trash about other people's parts...
- Spews out a cloud of somke when shifting
- Motor dies
- Traction problems/track times
- code 26 & 28 HELP PLEASE
- Bad news...tonight I find out what happened.
- new 02's are too short, what to do?
- tune
- 383 stroker .... fuel injection maybe?
- Pushrods, Roller Rockers, Lifters
- can it be done
- Can you prime the oil pump with the motor in the car?
- 1993 383 LT1 into a 1995
- calculate this compression
- Please Someone Help With My Cooling Fans!!!
- Bore opening in Fel pro head gasket?
- CA Smog Time Again - HC Question
- Solid Roller setup, Suggestons wanted
- Idea for reducing roller rocker noise...
- Gear swap???
- Can I pass inspection with a pro ram single plane intake?
- New engine ran great now no spark, ideas?
- Edlebrocks new LTx manifold, any split BLM issues?
- 847... stock motor?
- Cam Question
- New Best 11.28@118
- gen I and gen II conversions?
- LT1 engine questions..
- gms maf question
- hooker headers - Uninstall?!
- Bolt-on 96Z 6-speed dyno
- Failed Emissions with high NOX
- Lt1 swap for Carb'd sbc question
- If you have a HOTCAM KIT come here for a min!
- vids of my bolt-on lt1
- Fail Dallas Texas emissions need help
- Horrible Clicking Noise
- Decided to go with a GM sbc 400 bow tie block and dart pro 1 platinum aluminum heads.
- why did gm go with the opti?
- New Best, but bye bye trans!!!
- When Optis attack!
- I found AFR SMALL BLOCK CHEVY 227cc LT4 BARE RACING HEADS on ebay for $800 per set
- stalling woes!!
- Car runs bad when low on fuel
- 94 LT1 missing and surging
- Strange Misfire/Stumble/Hesitation - Need Help Please!
- When adjusting hydro rockers...
- Vented Opti Question
- Building a 396 from a bare LT1 block. I must decide on heads before I buy stuff.
- Push rod thru rocker arm
- Best H/C set up?? HELP!
- Apology from LR
- le2.2 cam degree
- Hei Distributor Conversion
- Smoke comes out of my engine.
- Mallory Cap and Rotor
- Block off plates...
- gm 847 with 10308 spring kit
- Adjusting Valves
- Problem with my LT1
- question about putting a bigger cam in my 94 lt1
- Anyone have OTVC wires and TC?
- what to do
- Dart heads for LT1??
- anyone ever install Cloyes Hex-A-Just on their LT1
- When the car is cold....
- What sensors could have gone out???
- Leaking intake manifold. What does it hurt?
- installing opti right now. little, easy question
- Valve springs
- What are the differences between the '94 & '95 cams?
- Doing some thinking
- help on plugs wires
- P0300 on Devil's Night - Long
- Crank hub install?
- where to buy the 4 washer seals on the back of the heads?
- HELP: Stalling - What sensors are used with/without MAF
- Fitting a real 96Z28 SS or 97 SS intake.
- code 97 problems
- Oil Pressure Problems
- Engine knock when cold
- New Delco MAF sensors.
- Noo. It's gone
- New PB 1/8th For Light Bolt On LT1!!!!
- Can I run Vette wires in my Fbody?
- Z runs fine cold once warm or "open loop" Missfire at idle begins
- Missing at Cruise/Part Throttle?
- Big Problems On Rebuild!
- Evap code P0441
- Alternator
- 5.3 Heads on LT1
- What would work best on my car with after market heads ?
- Car Is At The Doctor
- Idle vid of H/C/I LT1
- Better or worse gas mileage with Lts
- Injection Perfection
- Finishing out a set of CNC ports by hand
- Whats does this go to? Whats it for?
- march underdrive pulley belt without compressor
- cold start high idle
- why am i not getting spark on my lt1
- Weird Idle....
- Injectors / T-Body
- my car is overheating??
- New times and almost 10s on the bottle.
- Engine after starting seems real rich
- got power but won't crank
- New times since my last outing over four years ago.
- good spark plugs and
- Just ordered my Fuddle 3600 stall.
- 97 z28 engine
- GM Forged crank from older small block
- Pulling the hub, just want to double check
- Drivers side Head
- Starting issues
- car running weird.. urgent help needed
- overheating problem
- Oil leak, need some advice
- could and would a bad PCV cause..
- Kinda new modding, looking into LE1
- never heard of anything like this before
- water keeps comeing out
- Need some help with bad running car
- Tryin to get my radiator out...
- converting an 86 2.8 to a 93 lt1
- Head trouble
- How do u put the belt back on the crankshaft?????
- Coolant on piston
- 1994/1995 harness interchangable?
- early/late lt1?
- Eagle crankshaft
- Opti or cap and rotor?
- engine isnt running quite right
- Gmpp intake and carb kit question?
- New best
- opti or something else?
- low oil pressure/slight knock
- how can i find out what header bolts will work on my car?
- Machine shop problems again. Banjo bolt hole stripped.
- car is making knocking noise
- question about crank selection
- head gasket selection
- cams that have passed emissions?
- Cams. Shift Points and Peaks?
- Cam installed and the car won't start!!
- Miss-fire related with the MAF
- I have a feeling of helplessness with my h/c swap
- false knock?
- Will this make a good project car?
- MAF Question (no start, barely)
- Camshaft Timing and degreeing the cam?
- New Best 12.16@111mph!
- ~"~ Anitfreeze boil-over ~"~
- Is it possible to screw up a nonvent opti install?
- aluminum LT1 heads on old sbc
- Timing set install for stock lt1 question
- My Grounds Reading Hot!! Help!! Please!!
- i have a ?
- Need help installing distributor cap..??
- Another question, optispark not sitting flush (pic)
- Timing set assembly question (with pic)
- Perimeter bolt valve covers-whos got 'em?
- Finally...track times
- Need some quick, quick, serious help
- Lucas 42# injectors
- ignition wire seperators or LOOMS for lt1
- accessory bracket install....and accesories
- 383 solid roller combo
- Header Install Question - What to do about stipped heads?!
- block size/weight and how to ship it?
- anyone identify this LT1 PCM?? strange mods done to this one...
- does this cam look good to reuse?
- 94 Z28 need help/advice please.
- cold start low idle rpm
- How many cubic inches can the LT-1 be enlarged to?
- Anyone sell or suggest kits of mods that go well together and real results?
- custom cam help
- have a question and need opinion about compression.
- Can someone take a measurement for me please
- 503 cam parts needed
- stock rockers for the comp 306 cam?
- LE3 or Procharger??
- Coil Vs OPTI
- My higher rpm dyno issue? Opti-sensor?
- Head Gasket Selection
- Speedometer not working????
- le2.2 almost ready to go in . need to get your opinion on compression
- Vacuum not hooked up?
- hard starting...
- How strong of a Cherry Picker for engine removal through bottom?
- Dyno this Saturday 11am
- Any machine shops in south florida
- Is this hole supposed to be here?
- will car start with belt off?
- Aftermarket throttle body?? Which one??
- throttle positioning sensor
- thinking about a new oil
- msd 6al to lt1
- GM plug wires $250+tax??
- 96' Roadmaster engine into 95' T/A..Problems?
- I'm going through TPS's often!
- If LS engines can be sleeved larger bore, why not LT1?
- RPM's stumbles
- Boring a stock TB - tips wanted
- 36# or 42# injectors? For 396LT1..
- Accel Optispark plug in!
- What springs with cc306?
- where does this plug in?
- balancing
- Y-Pipe question
- V6 to V8 swap, need help wrapping it up.
- Pulling my motor...
- How to attach heater hose?
- Need some help
- Trouble Codes MAF O2.. where to start
- **VID** FASTFATBOY on the local 600ft track
- LT4 heads and intake
- Last word on injectors--promise.
- http://www.eportworks.com/lt1.html....anygood?
- Battery drain...
- Help! Car rough and loses power under load
- Do i need a distributor cap and rotor or jus the cap??
- optical sensor
- Idle/Missing - Overall CRAP! HELP!
- Think it's time for a new battery?
- Running Rich
- 1 cylinder not heating up..not firing
- will car still run with Blown Head Gasket?
- 396 Lt1
- heads?
- longtubes and ground clearance?
- speed pro pistons
- Oxygen sensor wires
- Removing radiator
- car wont run right after cam swap "help please!!"
- Backfiring !!!!! Cant Find The Problem
- Removing the heads
- 24 or 30 lb injectors?
- summit lt1 kit
- what is the long plastic piece off the air intake for?
- misfire problem..plz help
- Maincap?
