View Full Version : LT1 Based Engine Tech
- Got a vibration in my Clutch...Need Help
- 96 impala ss motor into 94 z28
- what size header bolts? can i use the 1 inch bolts
- cnc motorsports timing chain set ???
- i need some opinions.
- Snap On
- Rebuild w/o Block Work?
- high idle while moving
- Valve springs
- Testing my Opti ???
- cooling issues...
- Code PO443
- few questions! (lifters/pushrods help)
- 357 build ?s
- Please educate me on valve guides...
- Coolant on water pump valley near the bolt?
- Went WOT, now runs rough. DTC 13
- LT4 valve cover trim kits?
- Need new opti...options?
- Please I need help
- Questions on Delphi O2 Sensors.
- Engine install
- Ram air ?
- engine idle too low
- a few update pics on build!
- How to know what rear end gears u have
- retainer help NEED HELP FAST
- Questions
- Quick Alternator Question
- Pushrod length change when changing cam only???
- 1/4 mile times & HP
- Galley plug location
- Bored, Engine bay fuel lines
- Has anyone seen these, or atleast tried this?
- timing set issues with Cloyes 3145 and Ai cam
- Sanity Check, just primed the engine
- stock crank vs Scat 9000 Series Cast Pro Stock
- Nitrided Valve Springs or Regulars?
- LT1 DTC Codes (Help)
- Cam only car which cam
- LE1 heads with 847. My goals and ??s inside.
- Back pressure
- 383 burning oil
- 383 burning oil
- head removal
- Going to port my stock TB
- Help with 1.6rr
- Shift points for '96 Z28 A4?
- LT1 355 and not internal balance?
- Pics og my 355Lt1 to 383LT1 swap :D
- AC Compressor Wire Connector - Where to get?
- New camaro = forgotten Lt1?
- Optispark Install
- Rear main seal spacer???
- Spare 3/8 NPT Fitting
- Looking for a stock 96 M6 tune
- Carb on 96?
- Car goes nuts when it goes into closed loop, 02's? look at my data logs
- 2-Speed LED Fan Switch
- Cars Been Sittin Awhile
- Putting headers on Saturday
- P1441 - manufacturer control. aux emission controls?
- my issue
- special material air foil "Holley"
- many miles does it take before an LT1 is shot
- Name that Camshaft
- Failed Optispark
- Hardened Pushrods w/ LT4 Springs + RR's?
- Throttle body cover?
- How much HP with MAC headers and y-pipe give me.
- valves size question..
- So I got bored today...
- head job?
- Rough idle, hesitation etc
- How can I tell if a short block is balanaced or not?
- Bolt holes under throttle cover
- running engine without water
- My fans are making a high pitched noise
- How many people have deleted power steering?
- Will this work? What else?
- Car won't stay in closed loop. Whats causing it?
- MOST limiting factor on my 383??
- losing coolant? air pocket possibly?
- Madz28 vs. PCM4Less
- What's the first to go in the bottom end?
- LT1 trouble...need some help.
- Engine problem
- My Dyno Results: The Good, The Bad and The Great! Pics/Video inside
- has anybody run the Crane 109621 214-222 ?
- question ref proform v/c- where can I find the bafels at in the covers
- Fuel Questions
- Odd balancing question
- Cleaning the block for head swap?
- Has anyone put the stock radiator Vertical? Also whta after market rad?
- How would i test my electric water pump?
- 1st Gear Ends At 52 M.P.H. With 3:73's.... How!?
- stock lt1 exhaust diameter
- haha got rid of knock for free! sort of
- Whats everyones MPG for their LT1's?
- Mad Z28 Tune?
- Gas smell inside car.....Anyone?
- And now for something totally different!
- Someone describe nstall process Elecwater Pump
- Is my 1997 Z28 flooded? Odd situation..
- no spark
- Fixing a oil leak.
- Bad Starter...Again?
- evaporative emissions ?
- Who has run eddy performer heads???
- LT1 MAF question...
- Just bought 96 Z28...Dyno numbers
- 383(please dont kill me)
- dyno number seems high
- Sprung a radiator leak
- Underdrive question
- Crane ignition
- 5w-50 Synthetic Oil
- LT1 Issue inside(after spring/lifter/58mmTB install). CSV/Datamaster file available.
- LT1 Cam
- Gtech in a 93?
- 918 Beehives...LT1 compatible?
- Lt1 operating temperature
- motor mounts
- Can the Camshafter Retainer plate be welded on with cast iron block
- Electric Water Pump
- 93 z-28 cooling problem
- lt1 cam in a vortec engine?
- Trick to loosen O2 sensor?
- Vacuum Gauge readings at Wide Open Throttle
- LT1 & LT4 corvette valve covers
- Long Tubes for 96 LT1
- How loud is this 3.5 in Mufflex system going to be?
- want to get otvc wires
- ls1 heads?
- max lift with oversize valves
- Spark plug wire routing with LT headers
- OBD I PCM not closing relay????
- O2 sensor milivolts...
- opti ???
- Still breaking down. . And No clue what the problem is
- replacing injectors
- EVAP purge solenoid ???
- aftermarket coolant resevoir/overflow
- Getting baseline numbers for my project
- Next mod...Stroker vs Boost vs Nitrous...ol dear
- strange ticking / ping?????
- 3.480 or 3.500 crank?
- Need cam advice
- IAC stay over 75
- 5.7 rod or 6.0 rod???
- you wont believe what comp cams told me
- Setup Questions
- lt1 using anti-freeze
- Eagle Rod Clearance question
- How hard is it to rebuild LT1?
- Motor and tranny are in!!!!! Lots of Progress!!! PICS
- Manufacturer of LT4 Injectors.
- Back into an LT1!
- $8.62 Performance Chip from ebay?
- Is my fuel economy normal??
- carburated motor in 94 firebird
- oil pump drive gear material?
- LT1 rotating assemblies...forged!
- Mkay... LT1 383
- Cooling system problems
- LT1 overheat after waterpump install?
- timing chain slack
- Help me, car is missing badly
- witch O2s best with 110gas
- Coolant in the oil.. Fixable?
- Oil pressure 0-15psi any ideas?
- I'm doing seafoam, need help quick
- Need part # for hose..
- P0335 and P0336 codes
- Lt1 overheating
- pulling motor tranny bolt help
- headbolt torque
- Z06 engine swap into LT1 Camaro?
- Crane/ Comp/ Summit 1.6 SA RR
- momentary switch
- MSD box location pictures?
- Lt1 Mechanical Oil Pressure Gague???
- cooling fluid leak
- ARP header studs
- New Style Delphi O2 Sensors ES20022
- Gmhtp Wants To Hear From Lt-1 Owners!!!!!!
- Vacuum Diagram?
- .030
- How do the numbers sound?
- What springs? (bolt on only car with 1.6s)
- coolant overflow tank?
- Piston ring replacement?
- How To Tighten Down Rockers
- Any way to flush radiator while out?
- Accessory question
- radiator fluid 2
- cc503...stock rockers???
- Will I need new Injectors?
- Cruising Gear?
- water pump drive shaft
- Stock B-Body Cam Specs?
- 52 mm t/body
- Transmission Question
- !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!heeeeelllppp!!!
- Urgent Help Needed! Please...
- Lt1 to Ls1 Swap?
- Best place for Pro-grams?
- Problem with fuel pressure
- Oil pressure guage jumping around at idle?
- sanity check on rebuild plans....
- New o2s is this right? Pics inside
- tips for passing inspection
- New Engine Sat Uncranked for 1 1/2 years.
- EGR, AIR, and TB Bypass
- Exhaust still smoking after being shut off.
- aftermarket rocker arms
- 95 Trans Am Ws6 Starts then dies
- I give up with the heat issue
- rocker stud heli-coil
- Need Oil Pump Information
- where can i get the egr plate block off kit
- mallory 685 box???
- msd opti
- ??? 90-degree Aluminum Elbow For Lt-1/l-98 Throttle Body
- GM847/cc306 dyno chart?
- lt1 OBDII tuning
- 1994 LT1 with 184K Miles..heads and cam?
- icm or coil?
- ? For Lt1 owners with Ram Air
- Painting valve covers
- LT1 over 7000
- oil press. prob. and I have manual guage
- Engine clicking noise...runs terrible :(
- Knock after tune. What caused it?
- comp xfi cams
- Want To Guess My Power (rebuild)?
- 1993 motor into 1994 car harness help
- How fast do you think???
- Okay to build a 383 stroker myself??
- Crank bolt coming loose
- FEW new parts today!!
- ported intake and 58mm tb?
- Opti replacement
- Stock 93 Lt1 Which Cam?
- 915 comp behive valve springs
- I just want to thank you guys....
- ovcw
- Hooking up Oil Pressure Gauge
- Bearing question
- Some questions about valve springs and valvetrain geometry
